Hogan and Jakovlewich overunity generator
Started by hanon, July 07, 2014, 02:03:04 PM
nix85
Quote from: hanon on August 09, 2014, 06:25:40 AM
Hi all,
I think that the principle under Hogan and Jakovlewich generator is the same as in one of the Clemente Figuera´s patent. I am referring to Figuera´s patent Nr. 30376 (year 1902), the one with the rotary induced circuit and stationary internal and external electromagnets (Link to pdf).In this patent a SINGLE MOVING WIRE crosses between TWO OPPOSITE MAGNET POLES. According to Figuera´s patent text this configuration produces electricity without dragging the movement of the induced wire.
The key for avoiding dragging is the use of two opposite poles to generate the induction in the intermediate wire:  N -- | -- S  ; in contrast with common generators with just one pole exposed to the induced wire.
       1- A wire is settle into a moving magnet system, between two opposite poles: North and South
       2- As a consequence an induce current will appear in the wire
       3- This induced current generates a magnetic field (B) around the wire
       4- One pole (let´s say  N pole) will repel the wire because of magnetic repulsion with the magnetic field in the wire (creating a drag). But the other pole ( S pole in our example) will attract the wire (magnetic attraction between the S pole and the wire)
       5- Therefore the net sum of both forces (repulsion + attraction) will be null and the wire finally will be moved without any drag while at the same time will generate an induced current.
       6- The force of repulsion suffered in one disc (magnet 1) and the force of attraction done in the other disc (magnet 2) will be transmited to the common shaft. Therefore the net sum over the shaft will be cancelled and the machine will rotate without any drag.
I think it is as simple as explained here. Figuera also stated that he could not believe how such a simple principle had not been used before him.
Hogan and Jakovlewich patent requires two opposite magnets instead of just one. All Figuera´s patents are based also on the induction created between two electromagnets, instead of common induction with just one pole exposed. IMHO, This is the key of his discovery.
I attach an sketch with the representation of this principle. Please study this sketch and tell your comments. Both patents (Figuera and Hogan & Jakovlewich) share the same principle, and both patent are representing an overunity generator withoudt dragging. Please have a look into Figuera thread in the next link:
http://www.overunity.com/12794/re-inventing-the-wheel-part1-clemente_figuera-the-infinite-energy-machine/msg413741/#msg413741
I used to think this must be right but it's not. I see "logic" of the poster but in reality wire doesn't see two poles, there is single field and wire is repelled from it on approach and attracted when leaving it, just as the opposite is true, if we placed that single wire in the field and let the current through it, it would be ejected according to lorenz force aka left hand rule up or down depending on the direction of the current.
At least that's what seems to be the case. The question remains what did Figuera really do.
nix85
Quote from: nix85 on May 26, 2020, 04:37:27 PM
Not only that seems to be the case, that is most definitely the case.
