Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
TheoriaApophasis
Quote from: Bob Smith on July 18, 2014, 09:24:49 AM
This would imply that magnetic fields have a frequency(ies), which is/are directly related to the frequency of the "time variable electric charge and currents"?
Yes, Gyromagnetic ratios, and magnetic precession is nothing of my discovery, this principle is part and parcel to all magnetic
resonance imaging (MRI), nuclear magnetic resonance imaging (NMRI) technology, however the entire field of MRI technology
is senseless and clueless that a permanent magnet exhibits this due to a special magneto-dielectric field geometry. MRI use enormous
power to generate these magnetic precessions, which field contrasts are then used to image and determine what is being scanned.
Enormous pulsing power is used in the creation of MRI images, however a single large pulse is used to create an identical precessional
magnetic geometry in the permanent magnet. As is the case with most technology, things are discovered and perfected without
actually understanding or caring about the principles behind them
Every once in awhile, I hear about magnetricity, which seems to me to be based on the idea that magnetic "current" can be harvested and used to light up lightbulbs and power motors, etc.,.  Most explanations I find are either steeped in new age ideology and terminology or articulated with antequated notions of electrons spinning around atoms or are secretly vague/abstruse or a mix of all three.   My question:  In your opinion, if magnetricity were possible, would it have to do with influencing or tapping into the strength of the dielectric plane?
Well, taking the position of CP Steinmetz, Heavisidse, Tesla and others, there is no such Unicorn as a "discharge particle" , i.e.  the 'electron'.   It absolutely does not exist, and its mental creation is a false understanding of the function of charge transference.
No, said "magne-tricity" (your term) is not possible, magnetism is definitionally radiation and always a terminus posterior to a prior.   We all know how to get electrification by movement of a polarized (=magnet) field, but magnetism is not an entity that can or could exist of its own accord.   It exists inter-atomically resultant to charge, in T.E.M. and macro-magnetically in a "magnet" resultant to its disequilibrium from electrification where the interatomic magneto-dielectricity is WAY out of balance.
By "new age" you mean the CULT OF QUANTUM which makes nothing, invents nothing, and only produces mental fecal matter.
The people that invented 100% of our modern world , Tesla, JC Maxwell, CP Steinmetz, Heaviside, they all collectively spit at this mental midgetry that has invaded current "science".
If the dielectric plane is where the "pinch" is located, is this not where the real power is?
Yes, that is the case.  A magnet is "squealing" from dielectric 'pinch'  ;D  ;D  ;D
grab a mouse around his mid-section and squeeze, listen to him squeal.   ;D  ;D  ;D   (humor) Here be the magnetism in a "magnet" (electrified dielectric object) "squealing" with polarization
ROFL
OF WHICH under a perfect condition is 3.23606 parts dielectricity to 1 part magnetism
ALL of this is detailed in the book.
SEE the "Squeeze"  !!!!!   ;D  ;D
TheoriaApophasis
Quote from: Dave45 on July 18, 2014, 12:18:58 PM
Thought you might be interested in this.
This coil was powered up with ac 12 volts placed in water and frozen.
You brilliant bastard!!!!!!!!!  ;)     Have you tried that with a conventional neodymium magnet yet
Wonderful work!!!!!  ;D  ;)  ;)
thanks for showing those pics!!!!!!!   You're AWESOME
TheoriaApophasis
Quote from: nathan97 on July 18, 2014, 11:05:38 AM
See this one ? Neo magnet spinning in between two sheets of highly diamagnetic pyrolityc graphite
http://sci-toys.com/scitoys/scitoys/magnets/pyrolytic_graphite_2/spin.gif
Yes indeed, I have LOTS of  pyrolytic graphite     ;D
see a bit here:
https://www.youtube.com/watch?v=6je5P1BOp3A
Bob Smith
Thanks TA,
I'd better get reading your book.
Was that a rodent coil?  ;D
TheoriaApophasis
Quote from: gravityblock on July 18, 2014, 07:37:15 AM
The magnetic field moves with it's source!
Exactly true.   I can easily and PERMANENTLY ruin the magnetic gauss rating of a magnet to a great degree by horribly deforming the dielectric inertial plane by applying a LOW VOLTAGE (6volts) in small quick pulses along the inertial plane.
Every "magnet" has its 'engine' in the dielectric inertial plane at the midpoint to ANY and EVERY magnet which is ALWAYS self-centering and part of field incommensurability in a magneto-dielectric conjugate system.
