Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 74 Guests are viewing this topic.
SeaMonkey, Captain Zero:
When you try to imply that I am a "paid operative" or whatever, I consider that reckless endangerment and you potentially put my life in danger.  If my name ever slipped out, then it would take five minutes to know where I live and where I work and what I look like.
The percentage of mentally unstable people on the free energy forums is certainly much higher than that of the general population.  I don't want a nutcase to drive an icepick through my skull while I am walking down the street.  Do you get that?  Stop trying to imply that I am something that I am not because you recklessly put my life in danger when you do that.  I don't give a sh*t if the chances are small, it doesn't make any difference.  You guys disagree?  Then both of you go ahead and post your real names, your pictures, where you live, and where you work.  Not going to do that because you are uncomfortable with that?  No sh*t!
Just recently Captain Zero took some pot-shots at me and then actually made a posting ENCOURAGING other people to attack me.  Captain Zero, you stop that also.  Do you understand me?
I am not going to be murdered by some psychotic pulse motor psycho that is being egged on by some free energy sourpuss that dislikes rational thought, and you two stop it right now.
Theoria:
Re:  Your explanation for the ferrofluid cones.
Quotesimplex lowest pressure seeking mutual reciprocation
What do you mean by 'simplex?'
What pressure?  What are the units for this pressure?  How is it measured?
Mutual reciprocation of what?  Reciprocation between what entities?
How does this all explain ferrofluid taking on a conical shape when under the influence of a magnetic field?
TheoriaApophasis
Quote from: gravityblock on July 19, 2014, 06:32:18 PM
Call a photon whatever you like, but it doesn't change what it is!
I agree in premise,  ;D  ;D Can call a rose another name, its properties are the same.......
however CANNOT agree definitionally
, because all it does is PROP UP the ENORMOUS BS of Atomistic "unicorn particles" that make up the bread and butter of the Cult of Quantum.
GR and QM are 100% no different than ancient Greek Atomism.
To make any cultist of GR or QM twitch like a worm... ask them to "define a field"  ;D ;D
You said:
""""You don't believe in photons, electrons,""""
You dont get it.    A: what I "believe" makes no matter, what  IS , is all that matters.
You cannot keep using and evoking forth the PANTHEON OF PARTICLE BS  (of GR and QM), all it does is "feed the beast" that the Universe is an OCEAN of pixie-dust and unicorn "magic" particles  ::)  :o
No such pixie dust nonsense, these are mental excreta concepts from GR and QM.
Have you even READ the  horsesh*t that comes from fools like  Feynman (and the morons like him) to explain magnetism and action at a distance  ?????
   ;D  ;D
That Feynman and others have declared (as he has done in his mystical book: QED strange theory of light and matter) that
magnetism is mediated by "virtual photons" is no different than the Pope declaring mother Marry as healing a sick child from a
pendant worn at the neck. Humanity has placed, as dept. chairs in countless universities and likewise, heads of mathematics and
physics, people who are quite literally insane, are deep thinkers, but insane ones. The insane asylums of the world are full of genuinely
deep thinkers, however it is not for sake of deep thinking they are locked up and away from others! So, taking a cue from Quantum
mysticism we then ask the expert (fool) relativist "since you declare magnetism to be mediated by 'virtual photons', what is same?".
Answer received? Yes, here we have it: "A virtual particle is an abstraction, which facilitates in calculations and understanding, the
term is very vague and loosely defined, they never appear as inputs or outputs of experiments, their existence is questionable at
best,...however they are very useful in rendering concepts and making equations balance out". Well, insanity has been reified, at last!
Time should play the part instead of meters or distance. We should look upon Time as the result of the force that impels a body through space. The greater the force, the shorter the time, and the shorter also the space to be traversed. Thus, if the force were infinitely great, time and space would be infinitely small, they would cease to exist. If the force was infinitely small, time and space would be infinitely great. But, again the force is not everything, because in reality it does not exist. All that exists is the impulse that is applied to the body in space and imparts momentum to it. The body's movement is then only limited by the resistance it has to overcome. What does exist then is the momentum that arises from the impulse of the force, and not the force itself.
Time, like SPACE, is a POSTERIOR to fields.    Time is just another human perceptual SKR3W.
Time, like space "does nothing"  "acts on nothing" and "causes nothing".
Induction between fields extrapolated (wrongly) as = TIME is wrong, even the ancient Greeks knew this fact.
Like the world FIELD (Khora), people throw around the word  FORCE   ;D  ;D  ;D
Force = tension = induction = field interactions.
Reifications of attributional properties of ONE PRINCIPLE (fields [Ether modalities]) is only a convolution of simplex truths of how nature works.
There are no "lines of force" .....polarization is by definition a force of Ether pressure gradients WITHIN which space is present and therefore SO TOO IS FORCE present.    There are no forces in space, there is SPACE created in a field which translates INTO force as fields generate, terminate, move divergently, convergently, centrifugally, centripetally etc etc etc
charge / discharge   on and on.
Even Plato and Plotinus warned about reification of Xaos (space).   Its a necessitated (ananke  GREEK TERM) attribute of fields (Khora/ Chora).
TheoriaApophasis
Quote from: gravityblock on July 19, 2014, 06:38:23 PM
The light from the LED's warps around the magnets as it passes through the fluid.
YES, and all that does is prop up what I said in the book,  that light, having a radial dielectric component will warp around the DIELECTRIC INERTIAL PLANE of the "magnet".    ;D  ;D
Cap-Z-ro
Quote: SeaMonkey
" When men get all hypersensitive and start talkin'
like "wimmin" - it's the old power thing again.
Insult - Schminsult - now you guys are starting to
sound like Erron over at EF.
The Attackers here are very skilled at provoking
confrontational exchanges;  they're also very
good at deflecting responsibility.  They seem to
think their privileged status exempts them from
the rules of good order and discipline.  That they
have earned the "right" to play mischief in their
attacks.
Nothing is more pathetic than a Forum Man who
can dish it out but can't take the blowback.
You of course know to whom these references are
being made.
Set the Example of Gentlemanly conduct and it
will be found that Courtesy is Contagious.
Unless the Bad Boys persist in their fun...
But remember, there is a better Way. "
'Profoundly stated and undeniably true.'
And yes TA was somewhat condescending toward MH...but deservedly so...and is appreciated by me fror doing what NOBODY else around here has done...and that is make MH go silent.
The serenity was welcomed by many, but alas, short lived, as he has found shelter in the intervention of other wise but honest members who have begun to engage the theories of TA.
Rarely has someone (MH) who knows so much done so little.
Wattsup and GB are two of the most  knowledgeable members here, and people I respect and lean from...the other usual suspects, I have learned its best to scroll on by.
Their focus is on constructive ideaology, as opposed to the destructive negativity espoused incessantly on newly raised subject matter.
Such activity is regularly used by the gatekeepers to stunt the outgrowth of new concepts, which many times is the outcome of failed experiments.
Carry on 'gentlemen'.
Regards...
