Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
CANGAS
Quote from: 93RDELEMENT on August 22, 2014, 06:24:41 PM
If you all could stop the negative and just let go a bit all can work together to the greater good , you all have a lot of untapped talent and TA is a bit of a hot head but that will change he knows that but he has doe good with that magnet by videoing it and putting it up here and not hidden the facts but the formula is ??????? Also its time all the secrets of magnetism was held in one book and not in a hundred books ...
        SO THE HOT MAGNET IS ?????????????
A BIG PROBLEM FOR GLOBAL WARMING ! THERE IS A RED ALERT IN OUR LACK OF KNOWLAGE ! ALL THE PLANETS IN OUR SOLAR SYSTEM ARE ALSO HEATING UP NOT JUST OUR PLANET AND THE HOT MAGNET OPENS UP A WAY TO LEARN WHY THAT IS .........
WHAT IS THE COMMON KEY FORMULA THAT CONNECTS THAT TOGHTHER ?????? TRY A DARK MATTER SUPPER STRING !!! AND REPEAT THE FARADAY EXSPERIMENT FOR THE MAGNET !!! TO ALL WHO TRYS WILL ONLY BE REWARDED WITH TRUTH AND A LADDER TO CLIMB .......
ME
"AND REPEAT THE FARADAY EXSPERIMENT FOR THE MAGNET !!!"
Faraday did more than one experiment for the magnet. Which specific one are you bringing to our attention?
CANGAS 65
TheoriaApophasis
Quote from: CANGAS on August 22, 2014, 10:57:29 PM
CANGAS 65
Hes insane, case you didnt know
gravityblock
Quote from: picowatt on August 22, 2014, 10:44:19 PM
So if we are to believe, as TA stated a few posts back regarding the tape on the magnet's surface, that the magnet is actually warmer than its surroundings, why is the magnet not indicated as being unusually or uniquely warm at ca 0:20 and 1:07?
Just beyond the time slots given, the heat from the FLIR camera itself is reflected off the shiny, mirror like surface of the neo and directed back towards the FLIR.  In other words, the only time any unusual heat is observed from the magnet is when the FLIR camera can see a reflection of its own heat.
At 1:14, the tape applied to the magnet is less reflective than the magnet's surface so the FLIR camera cannot "see itself" in that area, hence no unique heat is seen in that area.
PW
I think the following proposed experiment can settle this issue.  The charge field is already near-infrared, so it is the charge field that is transforming the local and input energy, which is the heat (IR) from the FLIR in this case.   The LED bulb, has the claim of an efficiency of 200%.  The number 200% is found by showing that the energy output is twice the electrical energy input. The heat is coming from the charge field. The LED bulb is direct proof of Miles Mathis' charge theory.  What I propose, is to introduce an LED bulb into the magnet/flir experiment.
Gravock
picowatt
Quote from: gravityblock on August 22, 2014, 11:28:29 PM
Gravock
GB,
LED's in general are not "200%" efficient.  I believe you are referring to an MIT study wherein a very low bandgap voltage LED was operated at a very low voltage and current (while producing a very low output luminosity) and that it was observed that the picowatts of light emitted were greater than the picowatts of electrical power applied to the LED (and actually, I believe this was greater than 200%).  It was determined that under these operating conditions, heat was actually being absorbed from the surrounding environment by the LED and ultimately converted to additional light output.  It was also determined that while doing so, COE was not violated.
But I fail to see what this has to do with the heat from the FLIR camera reflecting off the mirror like face of the magnet.
PW
gravityblock
Quote from: picowatt on August 22, 2014, 11:54:28 PM
GB,
PW
You don't see how the magnet channels and radiates the heat coming from the FLIR?
Gravock
