Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
93RDELEMENT
Thank you cangass optimism is the food of inspiration and from which all knowledge is found ! To many here get tied up along the same thing and keep repeating it from one phrase to another ???? They need optimism to go beyond the present text to a higher plain of thought . Kenny here tends to hammer he's book into the wood he will need to publish it hahah But for me its all about building technology ,I wrote my book called the quantum mechanics tool kit and now use it to build all my technology with ...
Kenny please stop writing the same old book its about time you built something that has a particle use to it hahah To much data and no building is very boring  !!!! What is the point in data if you don't have a use for it ???? Its like buying to much food it just ends up rotting !
We need to build and plan and build share and co create the functions of our new reality into tolls that will change the world , We must get passed the one self point of view and build a solid bridge ! That is true cooperation and fulfilment empowerment and is what is required from our new science ..
It is here and now that we stand so Kenny no more data bombs let the talking begin !!!! Put your book in the book shop if want it we will buy it !!! Stop shovelling it down my throat I can eat it any more !! Its not complete and there for not ready to eat !! cook it with harmonics and stop hammering it or it will die ..............................................................................
No book of magnetics is complete without the either bubble ! I have the either bubble !
93rd
93RDELEMENT
I will now present the meaning and purpose of light by its harmonic construct held by the four corners of the universe that are in a 4 note harmonic event sent forth from the 4th second of the imperial birth, of all that is .. You will discover that light is the string that opens the void and permits the expansion and growth of the vacuum that is space .. The connection is tied to all strings within every galaxy and every galaxy is tied by these strings to each other with the final connections held out and firmly connected to the edge of the universe .. The curtain of space opens forming the void that is the vacuum and this in turn floods space with bosons which set up the path of negative residence allowing for neutrinos to function there position at an oscillation above the standard speed of light .
Light is complex yet it is seen as a simple string but within and around it are formations of the harmonic response that all strings emit even light it self requires the laws of harmonics to co exist within the vacuum and there for the cosmic octave is born ! This octave was first confirmed by the Hubble tuning fork a toll of immense importance so much so that the cosmological principle it self hangs between the void of its understanding and discovery ..
We will never travel beyond our galaxy without the reward of this knowledge that no longer need debate , one can only measure the length of the harmonic at the point just before you begin to travel along its path ! Each Earth Planet is also connected by the harmonic of universal harmony and it is with this we can locate with total precision the suns that hold all earth planets in there elliptical plain ! If you thought the universe has no plan you are wrong if you thought it would be impossible to know where all the earth are you would be wrong if you thought only chaos exists and by some stroke of luck we are here you will be wrong ..
There will be soon a day when all earth planets will finally connect and streams of information will flow between them and soon after the first teleportation of the photonic harmonic will be made and than mass it self will flow between them with no limits of time or space or resistance to hold down the darkness between the life we share ! I f you place limits on ability and constraints on the meta quantum it would be like tying your body and mind up with balls and chains and jumping into the deep blue sea .
To who it may concern I the 93rd element of the periodic will confirm the technology and the harmonic programme to make such thing possible ! For as one bold monkey like my self requires another to be the receiver of such reality only to confirm the matrix in harmonic response as true as it is day and night ! Behold for I am the omega the alpha the beginning the end and then there was light that brought man into reality so make no mistake as to the abilities of such truth ! To who it concerns let him hear what the spirit has to say write it down and build it solid and real and present it to all that are ready to measure all that is without meaningless debate or the utter carnage of mindless nonsense that is far to superfluous among the minds that limit truth over reality only to hear there thoughts like bells ring out of tune with the cosmic octave !
        I challenge all humanity
        To find all humanity
        ASAP
REGARDS
93RD
picowatt
Quote from: TheoriaApophasis on August 24, 2014, 07:47:59 AM
Actually asshole, Tesla delineated gravitational lensing without even seeing it.   Its due to dielectric centripetal bending of light.
It proves JUST THE OPPOSITE of relativity. It proves Tesla, Faraday, and Steinmetz correct.
Glad you brought that up boy.   Thanks for giving credit to Tesla.
Also proves my theory of light,
  thanks for the intro asshole.
Several scientists predicted the deflection of light by gravity as early as 1874 based on Newtonian gravity.
However, Einstein calculated and predicted the CORRECT amount of deflection in 1915 using his General Relativity.
This has since been measured many times with increasing degrees of precision and Einstein's calculations using GR have been determined to be correct.
PW
93RDELEMENT
Why does Kenny think Einstein IS AN IDIOT ????? Kenny cant do maths hahahahaha Your theory of light is empty without harmonics ! You fear it in the same way you fear the entropy test experiment on the magnet which I have now concluded ! The thing here is a lack of attention to detail that is something Einstein was abundant with . He never left the void without adding something to it that could be calculated in a factual way . Einstein would never stop at a heat signal and proclaim it as just a picture he would finish the job in the same way I have done ... Than he would carefully consider the facts and publish them . He would not stick picture on a tree and hit everyone on the head who happens to walk by with he's book call them scum and insult there grandmother ! Kenny even though I respect your driller killer instinct and your head for pretty pictures you must try and take a leaf out of the book of Einstein and follow he's example ! Do things the right way and you will be considered a man of truth ,there is still a chance for you its just that apatite for all things insulting that is a ball and chain that in the end will drown you ...
You could be an inspiration to millions of children or the biggest mistake that a child could ever encounter one that you must again consider in the deepest depths of the dark spot that is hidden in your mind ! Let go of the abuse and always say to your enemy's with due respect I consider you wrong ! That's all you have to say !
So you think you know light do you mmmmmmmmmm and you are a bit stuck with harmonic photonic response a term you have only just encountered and one you will in the end assimilate into your theory ! But when you have had enough of theories it will become the end conclusion !
A very simple example of the influence you may have on children in the future who may study this thread would go a bit like this !!! Little Johnny went to school and found a book called mumbo jumbo and the magnetic vortex which is a book I am now writing about you ! hahhahahaha ! FOR REAL !!! HAHAHAHHAH
Little Johnny found this book hidden in the black box where he's teacher hides all the bad influence he does not want he's class to have but little Johnny is very naughty and will stop at nothing to be bad ,,,, ahahha ! He ran home to read the book and in the next morning went to school after calling he's mum
A fucking idiot and told her its he's job to attack everyone he encounters and that he's scum of a father needs a magnet shoved up he's arse for fucking her in the first place .... hahaha do you see my point Kenny ?????? It gets even worse Little Johnny print up a 1000 copies of the book and gives them away to all he's friends !
Before you know it they make a full scale version of Einstein dress up as the Hitler youth and build a gas chamber than wear one of the gas masks you had used in one of your mad pictures and throw Einstein into a magnetic oven and pumped in a deadly version of either gas and ignited it with your tesla coil !
They than made a magnet image of you and began to pray to your image and vowed to kill all the people who love Christ and burnt a flag of Christ in your name as you have done here by words of dogma you wrote to describe the purity of the Christ .. They then made flying saucers and destroyed every school in the USA and imposed marshal law and attacked the image of the Queen of England and promptly murdered  everyone in Australia by means of force feeding them your book ..... This is only the beginning of the effects you will have if you keep up this disgusting track record of sickening abuse and attack of them like Einstein and the simple people of the world who refuse to obey to your new world order .
Any more and I will have to do something about it ! Even if I do like you IT GETS VERY UPSETTING TO KEEP READING YOUR ATTACK !!!! LET IT GO ASAP !!! Try and keep calm be open minded know you to are wrong !
        let peace be the light of tranquillity
        CHANGE MY SON
        PLEASE
TheoriaApophasis
Quote from: picowatt on August 24, 2014, 12:33:15 PM
PW
Actually, ASSHOLE, he didnt   Poincare' did.
and , asshole,  C squared came from  JC Maxwell, not Einstein.
Albert Einstein, Plagiarist of the Century
https://www.youtube.com/watch?v=i_jcTLetYr0
Most of relativity never came from Einstein asshole,  rather from Boskovich and Poincare'
Tesla outright accused Einstein of FRAUD
Tesla was right.
back to the books my little brain dead worm.
"The secret is hiding your sources" - Einstein.
Your little god was nothing but a fucking fraud.
343 PAGE BOOK:
http://www.solargeneral.org/wp-content/uploads/library/einstein-hoax.pdf
