Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
TheoriaApophasis
Quote from: TinselKoala on February 17, 2015, 10:42:34 AM
http://www.goldennumber.net/what-is-phi/
http://en.wikipedia.org/wiki/Golden_ratio
When you write it as 1.618.... it is a NUMBER. When you write it as, say, 1974/1220, it is a RATIO. You cannot however exactly specify it by a RATIO of any two integers, you can only APPROXIMATE it... that is why it is called an IRRATIONAL NUMBER.
Sorry, my drunk son, but its a RATIO, of 1 and "X",   that being  1 to Phi.
You missed the RATIO part of "Golden RATIO"  somewhere in your Vodka pickled mind.  ;D
See the pic below, a RATIO
A/B =  A+B/ A
SINCE ALL of nature is "written in the golden section"   its not only NOT Irrational, its the MOST RATIONAL
but you wouldnt understand such things
Wrong YET AGAIN, Kenny baby! Each and every Fibonacci sequence behaves the same way and will generate APPROXIMATIONS to the Golden Angle, just as the sequence starting with 1,1,... does.
You aren't even right about the original sequence being the "shortest" one, because all infinite sequences are "equal" in length and NONE of them arrive at the true value of Phi or the golden angle.
You can start a Fibonacci sequence with ANY NUMBER, and after a few iterations you can take the ratio of the last two numbers and it will be an APPROXIMATION of Phi, just as the one starting with 1,1,... produces an APPROXIMATION of Phi. What is it about irrational numbers and approximations that you are having trouble understanding?
I know.... you are just trying to protect your fragile ego from the acknowledgement that you are utterly and continuingly WRONG.
You posted a diagram that claims that 8/13 = 13/21 = 21/34 !  What more proof does anyone need that you are WRONG ??
Quote from: TheoriaApophasis on February 17, 2015, 10:46:48 AM
A/B =  A+B/ A
You now are redefining the strictly mathematical term "irrational number" according to your own fantasies, just as you always do when you are challenged. You can make up your own definitions of things all you like, it doesn't change the reality. All it does is demonstrate your lack of intellectual rigor and your willingness to distort reality in order to attempt to bolster your pitifully insecure ego.
ANYONE reading here can confirm for themselves what an irrational number is, and that PHI is one. According to the COMMONLY ACCEPTED rigorous mathematical definitions, of course... not your fantasies and made-up "definitions".
And I'm tired of your lying ad-hominem abuse, so go argue with someone else, I've demonstrated your fallacies enough for this morning.
8/13 = 13/21 = 21/34 ! Only in the mind of the Great Genius Kenny Wheeler !!!
TheoriaApophasis
Quote from: TinselKoala on February 17, 2015, 10:50:05 AM
"APPROXIMATIONS to the Golden Angle"
thanks for hanging yourself there, pickle.    ;D ;D
"start with ANY NUMBER"
Yeah, cause the Greeks and Pythagoreans and Da Vinci "knew" Mother nature started with the number 82, or maybe it was 104,  or, or or .
Youre drunk  ;D
The answer, is  1
always WAS 1
always WILL Be 1
everyone but the drunk knows this.
TheoriaApophasis
Quote from: TinselKoala on February 17, 2015, 10:56:15 AM
Golden Ratio is a RATIO, pickle,
not a number, nor an "irrational" one.
You Aussies drink too much  ;D
