Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
sadang
Great Atommix93rdAtom1! You reached the performance of another two persons here on this forum which have now a place of honor in my ignore list. Hope you will appreciate this and will stop polluting this topic.
AlienGrey
You will need to give us more info than that to help out or join in !
Err is it supposed to sound like this ?
https://www.youtube.com/watch?v=2cPEchNTSE0
CycleGuy
Quote from: wattsup on January 19, 2016, 08:57:09 AM
I like this sense of humor. It is challenging. Something like chess and your tone is like someone just made a checkmate. Not quit my friend.
Like I said such answers are there you just need to work it out. With the proper reflection, you will find it and you will see that the data will match as well.
The rock is also the cloud. The cloud does the same thing as the rock at sunrise, noon and sunset except that they are not anchored so the total atoms are involved and at night they also rest. When the cloud is there it's shadow is like the first layer of the rock so the actual first layer of the rock becomes the second layer of the rock even though it's the surface. When the cloud is thicker it acts like more layers of the rock and the rock acts like the 3rd, 4th, 5th ,6th ,7th layer of rock so they are cooler. Kind of hard to explain this quickly but you could integrate this into a system and compare the surface temp data - hehehe. They respond to gravity as well as their own inter atomic gravity within themselves and this creates what????????? Spin and spin creates what, more spin and soon enough even the air atoms are now spinning as well until they are so fast that they create what? Thunderful.
But better still. I am sure such a deeper line of investigation with SC would lead to anti-gravity.
As for QVZPE, if I can look at the past and progress to today, if QVZPE has been around since 111 years, where the F are the OU devices? So something is definitely wrong and I will not fix it. Just don't have the time. When SC is out, if they want to use it to fix their ideas, be my guest. But you can pursue it by all means. Let me know where you are in a few more years. I mean they are only years that pass by. Nothing important, just another life looking into QVZPE over 111 years, let's make it 112, just great. I could say more but it is NOT IMPORTANT right now.
Anyone working on OU device development in a commercial or donational way will always want a way to talk about where the energy is coming from so some decided to call it QVZPE, others call it Ether, others call it Quackery, while others want to handcuff it as the boson. Boson, Bozo names will only be names. If I looked into it further with SC, I could explain the effect especially if conductive atoms are involved in excitation or sensors taking down data. You can't get away from SC man. If the data produced is good, the construct, SC could explain it. SC is not your run of the mill construct ma'man. This is big. With SC, the world around you will come to life in its atomic wonder while others will still be scratching their heads with this QVZPE. But go for it if it does it for you.
SC will explain so many effects it just makes me cry sometimes because I know I will never be able to see it all. It's just way to big for one furt ass like me, I know. It's way to big so this is why it is very important that I be able to put this down as right as possible. It's just too big. I really think this will be the new basis. And I'm the guy that invented Wire X so don't worry, I have a habit of checking and rechecking and rechecking again to a very high level of logic. I'm just flabbergasted when I think to hard about it so I have to calm down.
wattsup
So clouds are gravity shields, according to your hobby theory. According to your theory, rain would fall upward, or at the very least would exhibit a variable level of gravity and thus gravitational acceleration, and thus a variable free-fall speed, depending upon the height of the cloud from which that rain is falling and thus the amount of gravity the total column of rain is blocking... your theory is even Whackier Than Wheelerism.
Now you'll have to account in your hobby theory for the Lamb Shift, a direct result of electron interaction with the QVZPE field... or just deny it, as you've denied the difference in mass of a proton and neutron and everything that isn't mass, thereby erasing the majority of the universe.
Just so you know, and quite ironically, inducing a synthetic inverse Lamb shift via Casimir Effect is one way of extracting QVZPE without any penalty of having to pay back that energy, and without the energetic cost of extracting it... you simply artificially lower QVZPE field density locally, which lowers electron orbitals of a noble gas inside that artificially-lowered QVZPE field density environment, causing that noble gas to give off photons which are captured and converted to electricity or heat. Once the noble gas exits that artificially-lowered QVZPE field density environment, it absorbs energy from the QVZPE field to return electron orbitals to their normal states, rinse and repeat. There are two methods of lowering QVZPE field density artificially... inside a well-shielded Casimir Cavity, or using specially designed magnetic flux paths (given that magnetism stresses the QVZPE field density, contracting or dilating space-time depending upon which magnetic interface you're considering).
And just so you know, the Lamb shift provides a very precise measurement of the fine structure constant and thus a powerful corroboration of Quantum Mechanics... the fine structure constant, which is exactly what your hobby theory denies exists. It's been known about for 100 years, and experimentally, empirically proven many, many times.
The above is what comes about from a deep understanding of the underlying fundamentals of how the universe works... one of the methods is patented and empirically, experimentally proven. Your hobby universe will never result in anything of the sort because it's even more FUBAR than Wheelerism.
You'll have to also account for magnetism itself... or weren't you aware that magnetism is an observed effect as a result of length contraction of the QVZPE field, the QVZPE field being the fabric of space-time? In your world, electromagnetic radiation could not exist, magnetism could not exist, light could not exist, time could not exist... the universe could not exist.
wattsup
@CycleGuy
What are you talking about? You obviously did not read my post otherwise you would not have posted such a piece of crap insults.
I told you already about QVZPE. If it involves conductive exciters or sensors I can work it out with SC.
Incredibly, what I gave you touches upon so many effects but if you prefer to waddle away in your QVZPE, good luck. Ask them the same questions you asked me and wait for their answers.
wattsup
CycleGuy
Quote from: wattsup on January 19, 2016, 03:31:55 PM
@CycleGuy
wattsup
Ask whom? The proponents of Quantum Mechanics? I have, they've answered cogently with mathematically corroborated replies which reflect underlying reality.
You've denied reality and dismissed things which refute your hobby theory, all while expounding upon a hobby theory that is so easily disproved even a child could do it by merely asking you to explain the universal gravitational constant in relation to your hobby theory... or asking, if clouds are gravity shields as you purport, why, for instance, cirrostratus clouds above lower altostratus clouds above lower stratocumulus clouds don't just float off the planet... or asking why, if one is in a tall building, the "gravity shielding" you purport occurs from all that material on the floors above and below one's location doesn't affect one's weight from floor to floor... or asking why clouds are able to effectively block gravity so much that the atoms of the rocks below don't swing wildly back and forth between the sun's gravity and the earth's gravity, thus heating up, as you purport happens as means of your getting around denying massless entities and thus photons and thus light, yet the clouds don't heat up so much the moisture in those clouds dissipates... or why, if one is on a submarine at depth, one's weight doesn't change with changing depth if all that water above and below is acting as a gravity shield (remember, you've stated clouds are gravity shields, and clouds are water... so seawater or lake water should be an even more effective gravity shield, right?)... so many examples that disprove the Wheelerization of Wheelerism that constitutes your hobby theory... none of which you can explain, let alone back up with mathematics.
And you'll have to further contend with the fact that researchers have now photographed the electron and the virtual photon flux that constitutes magnetism:
http://www.dvice.com/archives/2011/08/this_is_an_imag.php
http://io9.com/the-first-image-ever-of-a-hydrogen-atoms-orbital-struc-509684901
https://youtu.be/ofp-OHIq6Wo
http://www.newscientist.com/article/dn17983-magnetricity-observed-for-first-time.html
And you'll have to further contend with the fact that researchers at Chalmers University concretized virtual photons straight from the QVZPE field using Dynamical Casimir Effect:
https://www.chalmers.se/en/news/Pages/Chalmers-scientists-create-light-from-vacuum.aspx
Remember, your hobby theory denies the existence of anything that doesn't have mass... so no QVZPE field, no photons and most especially no virtual photons. Do you even know what "virtual" means in this context?
Your hobby theory is unworkable, it cannot reflect reality, as even a grade-school child could ascertain. I'll leave you to deal with the personal repercussions of your acceptance of that reality... but just know that eventually you will be required to acknowledge that reality. The only question, really, is how many years of your life you're going to waste denying that reality.
