Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 72 Guests are viewing this topic.
CycleGuy
{Sorry for the over-width images, I don't know how to get the forum to resize their display size.}
Quote from: minnie on January 21, 2016, 04:51:42 PM
   I presume a magnet works perfectly fine in a vacuum, therefore
  even if you think there's nothing there,there certainly is!
           John.
It depends upon how you define "vacuum".
In a 'normal' vacuum (in which there is no atmosphere, but the QVZPE field is present), a magnet would not see a diminished field strength.
In a 'perfect' vacuum (in which there is, quite literally, nothing... no atmosphere, no QVZPE field), a magnet would have no field strength... remember, a magnet is a folded strange attractor, it induces virtual photons from the QVZPE field to enter the magnet via the Attractive (centripetal) interface, they travel through the magnet and are expelled via the Repulsive (centrifugal) interface on the opposite pole face. No virtual photons from the QVZPE field, no magnetic field.
From another of my posts:
http://open-source-energy.org/?topic=1956.msg34981#msg34981
A conventional "dipole" magnet actually has 4 poles (2 Attractive and 2 Repulsive). Thus, a conventional magnet is "quadrachronologic" (when viewed from the perspective of both of the conventional magnet's pole faces).
The QVZPE field density is stressed twice on each pole face of the conventional magnet, once to slow time down (via the virtual photons thrown off at each Repulsive pole), and once to speed time up (via the virtual photons pulled in at each Attractive pole).
In short, our terminology for magnets is all screwed up, which confuses the entire topic.
                              Described Today As:     Should Be Described As:
Conventional Magnet:  Dipolar                       Quadrapolar, Quadrachronologic
Perfect Magnet:          Monopolar                   Dipolar, Dichronologic
Pole Descriptions:       N Pole, S Pole              Face 1 Attractive, Face 1 Repulsive, Face 2 Attractive, Face 2 Repulsive
We should be looking at and describing the Attractive and Repulsive poles that are intrinsic in each pole face of the conventional magnet. When we refer to an entire conventional magnet, we should be referring to it as "quadrapolar" and "quadrachronologic", rather than "dipolar". What we refer to today as "monopole" magnets we should be referring to as "dipolar" and "dichronologic", since a perfect magnet with all magnetic domains aligned in the same direction will have two poles... an Attractive (centripetal) and a Repulsive (centrifugal) pole.
https://forum.nasaspaceflight.com/index.php?action=dlattach;topic=36313.0;attach=825988
That's a PDF file entitled: "Pressures and Energies of Vacuum in a Magnetic Field. Differences and Analogy with Casimir Effect". Scientists from Instituto de Cibernetica, Matematica y Fisica in Havana, Cuba did the research for NASA. They show that the Attractive (centripetal) interfaces on a magnet "squash" the QVZPE field density closer to the magnet pole face, whereas the Repulsive (centrifugal) interfaces "spread out" the QVZPE field density. This is a result of the temporal (time-asymmetric) qualities of a magnet's interfaces.
Acca
Here is a link to Michael Snyder on magnetism. He is the original discoverer of the Hale Shaw cell and the magnetic flux lines ..2007
  http://overunity.com/15426/the-ferrocell/15/
Here is my old post from page 39 of this thread
Here is the Flicker photos of Michael Snyder he developed the single axis magnet plasmon viewer..  His YT channel is https://www.youtube.com/user/SirZerp/videos
http://www.aps.org/about/physics-images/archive/heleshaw.cfm
"Anti-Vortex Image in Hele-Shaw Cell
Magnetic fields can be hard to understand or characterize. Two natural means of visualizing magnetic fields are the aurora australis and the aurora borealis, as well as the Sun's corona.
Michael Snyder and others have explored ways to visualize magnetic fields in the lab. The visualization here started with a Hele-Shaw cell. A Hele-Shaw cell is two flat parallel plates separated by a nearly infinitesimal distance. In this case, Snyder's and Frederick's Hele-Shaw cell is made of two 100mm circular glass windows separated by a Fe3O4 ferrofluid; that is, a liquid of 10nm particles that becomes strongly magnetized.
The Hele-Shaw cell is facing the camera and illuminated by 36 colored LED lights placed around the cell's perimeter. The light is scattered through the cell as the ferrofluid particles respond to two magnets behind the cell which are aligned north/south and south/north. The magnetization produces this anti-vortex image."
http://www.revolution-labs.com/
https://www.flickr.com/photos/sirzerp/2947536208/in/photostream/lightbox/
Acca.
AlienGrey
this forum is suposed to be about sharing information and technical know how
Do we realy have to put up with this verbal abuse and foul laguage ?
AlienGrey
Quote from: Atommix93rdAtom1 on January 21, 2016, 09:54:17 PM
Look at this picture its the path of reactions but there is something missing that reveals the paramagnetic resonant Code and I just found it !!!!
Do you see all these Russian free energy resonant field technologies all depend on finding the paramagnetic resonance peak field of a coil set up and only now are they all agreeing that they get ill from it so its never going to work as a safe energy system if they keep doing it the way they are doing it !
Well I have found a new way of doing it and its the safe way !!!
Also I would like to have a bet with anyone that a magnetic field line is made of !!!!Nothing !!!! And In between the lines are particle harmonics as say trapped zero point fields set to a harmonic resonance equal to the intensity of that part of the field ...
Monopoles are holding different zero point particles like gravitons and bosons ! Confirming these two as the true fabric of space and time ! All the others hold the charge carriers .....
...........................................................................................gravity now isolated..............................................................................................
Yes, Yes you know a lot on the quantum physics level that may well be true, but time is getting short we need to move forward if you don't want to be a brain dead US captive slave in a fema camp.
Aliens usually give abdicates some sort of telepathic message of some kind about the earths future and how we can stop the idiots from destroying it, why don't you regress your mind back into that information and use it, help the earth and humanity before your freedom and ours is gone, forget about contracts money and self wealth most people are just existing,  the 5 percent of the rest are banksters and Politicians, Politicians have already been bought out till it all changes it looks world wide, so who is the Führer ? don't get side tracked, move on.
minnie
   Is a "perfect" vacuum attainable?
   ie. No QVZPE field.
            John.
