Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
tinman
Opposite spins shown here in this video.
Please remember-we are looking at MY setup.
https://www.youtube.com/watch?v=n358gtR7gr8
mikemongo
Here's a visually stimulating image of the big magnet we live on that clearly shows the accretion disc.
Map of all the tropical cyclones from 1985-2005, courtesy  http://en.wikipedia.org/wiki/File:Global_tropical_cyclone_tracks-edit2.jpg
picowatt
Quote from: tinman on July 24, 2014, 09:15:19 AM
Tinman,
i did not know if you would post, but I knew you would have to play!
Just a few suggestions:
1.  Insulate the shank/threads of the screw  to help clear the field of view
2.  It might be interesting to cut a 3" or so diameter disc from a piece of thin, fairly rigid, clear plastic material and cut a hole in the middle that you can slip the magnet thru.  Ideally the ID of the center hole would be such that it is a slip fit on the magnet OD.
You could perform several tests with the plastic disc in various positions along the magnet's length, i.e., close to the bottom pole, at the center of the magnet, and then near the top pole.
The use of the disc will help isolate any hydrodynamic/bubble flow from the bottom of the magnet (it will be forced outward and awayby the plastic baffle) which might assist in visualizing where flow is occurring.
3.  As well, you might try repeating the tests with/without tape on the sides of the magnet while the bottom pole of the magnet is insulated with a disc of electrical tape.
4.  It might be interesting to visualize/verify the flow in areas where bubbles may not be.  The use of a magic marker, or syringe/tube with food coloring injected comes to mind but eventually will cloud your tank.  Although I am not sure how well you would be able to video through a beaker or jar, moving the experiment over to a smaller container would allow you perform flow visualization within an amount of electrolyte more readily changed when it becomes clouded from ink, dye. or coloring used to visualize flow.
Food for thought:
Keep in mind that even with the tape applied to the sides of the magnet, the bulk resistance of the electrolyte, through which current flows, is generally at a right angle to the magnetic axis.  Also, regarding the observed flow, keep in mind that during electrolysis, there are ions involved.  As H2 is generated in a given area, the negative ions formed there are repelled away from that area.
The point is, it may be that we are seeing the effects of both (A.) bulk current flow generally towards, and at right angle to, the magnetic axis and hence a homopolar effect, and as well (B.), the repulsion of negative ions as they are formed during H2 production.  By convention, charges (or ions) of opposite polarity will be deflected in opposite directions by a given magnetic polarity.  As well, the current flow through the bulk resistance (electrolyte) experiences the fields of the magnet regardless of whether or not the magnet is insulated, so as bulk current flow becomes sufficient, it is not unreasonable to expect that the homopolar effect would dominate over any observed ion "wind".
PW
Acca
 To: TheoriaApophasis
Here below is the thread by Mark Snoswell, he was posting seven years ago on magnet vortex spin, I know that you will like this... Now Mark is the chief technology officer at http://www.chavaenergy.com/
Dr. Mark Snoswell, Chief Technology Officer: Dr. Mark Snoswell graduated from Adelaide University with an Honours degree in Biochemistry in late 70s. Mark has a diverse career since then including: PhD in Biotechnology/Biochemistry; CTO of Torson Inc – a global sports biomechanics and edutainment company; Founder and Chairman of Ballistic Media – a global corporation that includes BallsiticPublishing.com and the CGSociety.org; Mark is also the President of the CGSociety. More recently Mark has been developing breakthrough concepts for how our universe works and new devices to generate clean and abundant power using solid state electromagnetic systems.
http://www.overunity.com/2764/spinor-resonance-explanation-for-tpu-like-devices/#.U9EyaKyLN8U
Here are may old clips, looks like we are on the same track...
Thanks for the book !!! Now the was allot of effort !! Don't let the ass*oles get you distracted ....
http://www.youtube.com/watch?v=J1TnGGeeP0I&list=UUKp4xN6pwIVRqiKhtdc_Wsw
http://www.youtube.com/watch?v=SXifaqdbLhs&index=37&list=UUKp4xN6pwIVRqiKhtdc_Wsw
http://www.youtube.com/watch?v=wR7c4iXum-A
Ps..
"MileHigh you don't exist  !!! your words a worthless even with some 3000 posts !!"
Don't respond....!!
