Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
tinman
In this test,i have used a ring magnet from a speaker. Here we can see opposite spins,even though we dont change the voltage polarity,or the magnetic fields.
I have also found that it is the magnetic field that turns my camera off-if i get to close to the magnet.
https://www.youtube.com/watch?v=QCCA0rPiS5w&list=UUsLiBC2cL5GsZGLcj2rm-4w
TheoriaApophasis
Quote from: tinman on July 27, 2014, 05:52:57 AM
REALLY awesome vid!!!
Thou art not the person pictured below,....for thou doth indeed knoweth!      ;D  ;D  ;D
nathan97
Tinman, I have a trivial question: is the current flow in the two copper rings running in the same direction (CW or CCW) ?
Also, do you have a change to excite the copper rings with pulsed current ?
tinman
Quote from: nathan97 on July 27, 2014, 07:43:17 AM
Both copper rings are a complete joined loop,and both copper rings are the negative potential-as stated in the video.
Quote: Also, do you have a change to excite the copper rings with pulsed current ?
Not sure what you mean there.
TheoriaApophasis
Quote from: d3x0r on July 27, 2014, 04:41:00 AM
As a crude analogy, a magnet is really just like the "magic faucet" , except real (NO, not implying its magic at all).
People look at this, often seen at Ripleys believe it or not, and wonder how the hell it works.
In a LOT of ways, just like a magnet.
In the "magic faucet" , water (magnetism) pours out, and a pump sends the water back up in clear tube to the top again where it pours out......
In a magnet, the "pump" driving the magnetism (water) which flows is the dielectric inertial plane in the center (actually its everywhere, but forced to the midpoint by incommensurate magneto-dielectric geometry of opposite fields in a binding system, the "magnet").
While, in the case of the faucet, gravity causes discharge.........The perpetual ACTUAL movement of the water (magnetism / field of dielectricity) is gyromagnetic precession, the radiation and termination of dielectricity into "its field" (magnetism), ...the  (Larmor frequency) at which in the binding system, magnetism gimbals (at the nucleus) in precession in perfect dielectric (in discharge = magnetism) geometry (in a perfect magnet of course).
The RETURN centripetal convergence is just stereotypical field reciprocation since NO FIELDS CAN, NOR EVER DO 'TERMINATE IN SPACE' (this is a cornerstone of Maxwell, Steinmetz, Tesla etc)
No field can "terminate into space", they can into themselves and other fields, but space itself has no capacitance other than the inductive ability granted it by the field(s) to which it is a byproduct thereof.
http://en.wikipedia.org/wiki/Larmor_precession
So, while DIFFERENT,  this cute little magic amusement, is rather literally how a magnet works, (at least in rather very close physical analogy).   ;D
