Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
steeltpu
Quote from: MileHigh on July 20, 2014, 02:03:40 PM
Captain Zero you are the disruptor of this thread and the disruption started at post #215.  So either contribute technically to this thread or keep your mouth shut.
    milehigh you are the disruptor here.  no one wants your exploration stifling bs here.  you only try to stifle discovery and exploration under the guise of saving someone from wasting money which is more bs.  no one needs saving.  everyone has a choice and self responsibility.  many great discoveries have been made by accident.  you are either a twisted mind or working for people who don't want any new discovery.
you also have a choice to be here or not.  if you feel paranoid about spewing your crap here so go away if it feels unsafe.  you try to threaten others here and stifle free speech?  that's new for you and shows how desperate you are.  it's obvious to everyone here you are way in over your head with TA.  all you can do is insult and make foolish attempts to disrupt the flow here.
it bears repeating what TA said: you have a phd in lip flapping and BS.
fed up with your crap.  only have one more thing to say and i'm sure some others here can figure this out.  let's see if you are smart enough:
    676f2061776179206b696420616e642065736164
93RDELEMENT
NONE OF YOU KNOW ANYTHING ABOUT A MAGNETIC VORTEX ! You are all just twitting around, what a total load of nonsense ! Ions follow the path of the magnetic field in water and in air in fact the only way to measure a magnetic vortex is by an indirect method for measurement because via the spinning of an object . You must first understand what a magnetic field is made of its mass its spin the quantum mechanics of magnetism dark matter, monopoles, negative vector returns, the boson field , gravitons  the dark matter relationship between iron and aluminium . That's the begging than electron coupling, entropy of zero point fluctuations, the space time variable, Harmonic inter phasing within periodic elliptical events of primordial particles , Maxwell's equations , And finally how to isolate a free momentum of atomic mass over its compression of all the above .
I NO DOUBT YOU HAVE NO IDEAR WHAT I AM TALKING ABOUT SO DONT WASTE YOUR TIME GO PLAY WITH LEGO AND A BATTERY HAHAHAHAHHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAH
ME
Steeltpu:
I am not stating BS, you are fibbing.  So, do you believe that the magnetic field from an axially polarized disk magnet looks like a toroid or it looks like the attached image?
Which do you believe?   Tell the truth now.
P.S.:  Before 'sexting' there was 'hexasexting' done on 4 x 4 chicklet keypads.
gravityblock
Quote from: steeltpu on July 20, 2014, 03:45:12 PM
That is a hexadecimal (hex) number.
A hex is a magical spell, usually with malevolent purposes such as having a harmful influence.
Gravock
tinman
Quote from: gravityblock on July 20, 2014, 12:42:44 PM
This is nothing new and is nothing that is unexpected.  This is a traditional homopolar motor.  I have studied and experimented with homopolar motors more than anyone else on this forum, except for maybe broli.  You can find many youtube videos of exactly what you have done, except you have immersed your set-up in water.  If you use a ceramic non-conductive magnet, instead of a nickel coated conductive neo magnet, then you would get no rotation.  Prove me wrong on this, and I won't make another post on this forum.  Just make sure the screw that is attached to the magnet isn't running from the rim to the axis.  In other words, let the conductive screw only touch a small point at the center of the non-conductive magnet.
Gravock
This i already know.And  If i am the only one to have immersed it in water,then it has not been done.
