Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
TheoriaApophasis
Quote from: joel321 on February 20, 2015, 02:25:54 AM
What is causing the magnetic field in the earth?
immense rotary motion of the iron core resultant to the earths rotation......and induction from the sun to the earth which is perpetually inducing same via the earths poles.
What is causing the magnetic field in an earth rock (magma)?
frozen lines of induction from metamorphic rocks brought to the earths surface from plate shift etc.
Does the earth magnetic field has a vortex?
as to the liquid core, pure conjecture, as to the field itself, YES, obviously so.
What is the magnetic gauss of the earths magnetic field?
I forget the NASA measured quantity of same
Why do rocks sink in the ocean and not sink in outer space? (outside the atmosphere)
counterspace,
why is the IRON in earth at the center? , simplex........when still molten, the iron will always migrate to the lowest pressure gradient of counterspace, for the same reason a magnet will seek the center when put on top of MAGNETIC PUTTY   (ever use that fun stuff??????)
joel321
Quoteimmense rotary motion of the iron core resultant to the earths rotation......and induction from the sun to the earth which is perpetually inducing same via the earths poles.
YESSSS, the same way that we believe that the PHENOMENA is "molten" in the center of the magnet ELECTRICITY = waves. You don't see an iron core inside plastic which is also MAGNETIC too. Or an electricity conductor in low levels. The ironic part about magnets is that heat destroys their iron magnetism! So how can the earth be molten magma that produces magnetic fields while a magnetic field gets destroyed by heat? And not only that, your $4000 dollar magnet does not have molten lava in between? Throw your $4000 dollar magnet in a furnase where it gets molten and watch how it comes out less magnetic?
Quotefrozen lines of induction from metamorphic rocks brought to the earths surface from plate shift etc.
Dude, how is a hand held magnet become a magnet? = electricity. The universe is electric.....no gravity,  no black holes, no dark matter, is not the ether related to electricity/plasma?
Quoteas to the liquid core, pure conjecture, as to the field itself, YES, obviously so.
Does a liquid have stronger magnetic fields than a solid core? The reasoning in my mind is that a magnetic field in a solid is stronger than in a liquid. Show me a liquid hand held magnet? :) just trying to make you thing bro not trying to insult...just trying to learn life.
Quotecounterspace,
why is the IRON in earth at the center? , simplex........when still molten, the iron will always migrate to the lowest pressure gradient of counterspace, for the same reason a magnet will seek the center when put on top of MAGNETIC PUTTY   (ever use that fun stuff)
You have to understand why birds fly in the earth with out a magnetic field....the only reason birds fly is due to the repulsion od the gravity. Or should I say, ONLY, inside the atmosphere. Or are you telling me that birds fly because of the earths magnetic fields vortex? You might be correct but birds ride on the waves within the vortex of the atmosphere. The same as meators ride inside the outer space. Exept, I believe meteors have it easier cause they don't need wings! We can understand that even WATER floats in outer space with no wings!
Why does water float in outer space?
That mind boggling like asking, why does water float inside an ocean? Obviously, outer sapce is more liquid dense than water is water floats in outer space.
What is the counter space of water in an ocean?
just thinking here.
TheoriaApophasis
Quote from: joel321 on February 20, 2015, 04:45:58 AM
youre confusing MAGNETISM (polarization inherent to any and every atom in the cosmos), with the term MAGNET (coherent mass of polarized atoms)
common ERR.
Coherent induction. or likewise resultant pulse with same outcome.
There is no such thing as gravity, its a pathetic human term given for counterspatial acceleration. Its 'powered' by counterspatial dielectric charge.
The VISIBLE UNIVERSE is 100% magnetism. = SPACE
the cuvilinear nature of all movement and phenomena is due to COUNTERSPACE
All curvilinear motion = Vortex, or the "fight" between space and counterspace
WEIGHT is a meaningless HUMAN contrivance.    Weight is location and FIELD specific.
same reason a 40 pound 10 year old can MOVE a 600 pound person if both are in the water
sadang
QuoteDude, how is a hand held magnet become a magnet? = electricity. The universe is electric.....no gravity,  no black holes, no dark matter, is not the ether related to electricity/plasma?
And what is that thing you call electricity? Replacing magnetism with electricity or viceversa will not resolve the equation of their own manifestation. This is just a circular way of thinking, not an ascending one. This way of thinking will not bring nothing new.
QuoteWhat is the counter space of water in an ocean?
This a non-sense question! It is available only in a frame of thinking based on the existence of separate things, the observer and the observed phenomena being two separate and distinct things. Wrong premises, wrong development, wrong results!
There is no counterspaces, but only counterspace. Only one! The same counterspace for all forms of its manifestations, even if they can be called by human minds solid, liquid, gas, plasma or other terms invented by human minds. It is a fulcrum for all things know and unknown to conscious and rational human mind.
If you really want to understand things move the observer in the counterspace.
TheoriaApophasis
