Reflected gravity power...
Started by iacob alex, September 05, 2006, 11:59:43 AM
iacob alex
...if you take a look at   http://www.inter-corporate.com/forums/fieldpropulsion.engineering.html   Search#239...Imagine a power-mill at a "sky-sea" shore,as the waves come from the outer space.The starting "point" prototypes we have already,in so many draw up plans:the coming sea-waves power is  transffered    to a temporarily storage(gravity field) and then we make use of it.Look up,think alike.The same design,just a transposition,remodeling of the eternal atom/seashore-field/blue ocean  relation,romance,not ::) so secret rendezvous...    All the Bests!/Alex
gannigal
Quote from: iacob alex on September 05, 2006, 11:59:43 AM
Hi there:   You have a lot of ideas.  But one thing is for sure. That a perpetual motion wheel is very simple, otherwise if it is complicated it will evetually lock itself. As simple as that. I know this by experience.
Good luck. I will also do my best to rediscover this pmm.
        John galea       GANNIGAL
iacob alex
Hi Gannigal!Thanks for comments.So,a lesson of simplicity you can find at  http://www.youtube.com  added today,at category Science&Technology with tags "Motor solenoid magnet perpetual over unity" from Mervace.The words of the builder man are fully explanatory.His modesty is highly:the device is 15 years "old".As somebody said,"it's a cute machine and simple",really.I bet,as you,on the same idea:this gravity motion "machine" must be very simple.As you said "otherwise if it is complicated it will eventually lock itself".In other terms:are we looking for a statics machine(a balanced  weighing device) or for a dynamical one(an unbalanced falling design)?Always,simplicity is a good starting line.All the Bests!/Alex
iacob alex
...is an application of a general natural concept:reflexivity of motion.Let's say that I am a blind man,feeling and thinking  as a piston of yours ,so many combustion engines.At one side ,I have a feeling of the motion waves of "something"(alternate low pressure-high pressure ,a push-pull).I am bind exact to play ,to and fro on a line.At the other side,I have a connecting rod so to transmit this push-pull to a rotor,determining this one to turn continuously.I understand that I am an "in-between" only, in this transfer of motion ,but dreaming up(as you...) to hand down the gravity power,I am surprised about your designs:where are the waves,the gravity tidal  surge?Can you imagine an engine with no "high pressure"!?Can  you surf without beach combers,breakers?I am a blind piston-man only,take this as an opinion.All the Bests!/Alex
iacob alex
...   ask for a different,out of ordinary manner of reasoning?
    Not at all.
   We have the know-how about cumulating,collecting the power of the sunlight or the sea -side waves:the wave concept of the natural energy transmission.
    So,why not try to "pack",load,amass gravity as the waves  on the sea-coast?
    Up and down of the visible water waves on the beach in a gravity frame,can be a suggestion for an up and down in a rotational frame,a push-pull game with this general property of the space:....inertia.
        All the Bests!  /  Alex
