IS THIS FREE ENERGY?
Started by magnetman12003, August 07, 2014, 07:47:37 PM
teslaedison
If you read on Nikola Tesla papers you should understand that energy comes from the air which means its the earths center strong magnets that you can tap into and use it by using a certain gauge copper wires maybe in a circular degrees so the earths when its moving will allow the crossing of these magnetic flux lines of earth is some thoughts here !!
Thomas
Low-Q
Quote from: magnetman12003 on August 07, 2014, 07:47:37 PM
Check out this video and let me know.  I have been working on this for quite some time and
cant explain why no load is showing up on my wattmeter when a 120 volt LED 1 watt bulb is lit.
Watt meter measures entire load of function meter and home made free energy transformer plus the bulb powered and unpowered.
https://www.youtube.com/watch?v=BV2E82sJToU
1 Watt at 120 Volt require only 0.0083 Ampéres. Maybe that's the reason why you don't see a change in your Amp-meter?
