Need Leedskalnin PMH coil winding diagram
Started by magnetman12003, August 15, 2014, 03:06:32 PM
PolaczekCebulaczek
Quote from: sm0ky2 on February 03, 2018, 09:31:46 AM
Because we are above absolute 0 (and the new abs-0 by a new theory)
but below Tc
We must use the Brillouin function to analyze the magnetization.
The reduction of this equation tells me that there must be
A change in temperature in the PMH.
More specifically, it should 'cool down' when it locks
And 'heat up' when it unlocks.
Does anyone's know of experiments done along these lines?
I will tell you something; once I magnetized small PMH (using AA battery) and heat it using gas stove, IT DID NOT DEMAGNETIZES and so i found it strange ..PMH shows that magnetism is more concentrated inside the metal that outside and in loop, nothing special yet it still amazes me. I planning to heat it to very high temps soon.
sm0ky2
There shouldn't be any real change until it reaches the curie temp
Which for iron and steel is around 770C
But when it locks/unlocks there "should be" a change in temperature in the metal.
As a result of the change in internal magnetic moments.
At least, such is present in the mathematics.
(if there is an austenite->martensite transition)
I have yet to prove that last part....
But detecting a change in temperature would be a huge clue.
sm0ky2
Found a reference to this stuff from the 60's
Not sure how it never made mainstream magnetics
http://www.tandfonline.com/doi/abs/10.1080/14786436208213848
ramset
Smoky
noticed a magnetic capacitor being pondered
member Smudge [Cyril]shared these musings recently.
respectfully
Chet K
PS
the magnetic battery considerations [first PDF
and the magnetic battery jpg below
Thanks Grandma
sm0ky2
Yeah I built a really nice looking piece of hardware
and when i hooked it up , the cheap glue broke down
I've rewired it, but it doesn't look near as pretty anymore
Coated in lacquer this time
I'll post it in a little bit, lacquer is still drying.
I'll make a diagram too, showing exactly what I did
(why is a longer story)
The timing on that one seemed perfect, lot of guys building similar things lately
I had specific # of windings, wire lengths, ohmic resistance, etc. in mind
for another purpose, but this one might have several uses now that I see
what others are up to.
