Longitudinal Wave Experiment to demonstrate Overunity
Started by magpwr, August 16, 2014, 01:12:29 AM
poynt99
Quote from: magpwr on August 16, 2014, 07:37:22 AM
hi MarkE,
I got even better way to show OU.I am using  "1" Ohms resistor at output instead of using 250watt x3  120volt bulb to demonstrate the capability of this circuit.
The spike is nearly 100volts with 1 ohms resistor.
This time i would have to change fuse to 5Amp so my guess it is somewhere below 5Amps.
6.6volts x 5Amps=33watt input with around 98watt output for 1 ohms load."This is just an estimate"
The interesting part the output frequency did not deteriorate much with 1 Ohms load.
Latest update-I have attached single spike waveform using 100v/div in the 200ns range for reference using 1 ohms resistor.
Consider this (my estimate of output power):
Vpeak ~ 100V
Period T ~ 250us
Pulse width t ~ 200ns (assume nice rectangular pulse, even though it is closer to triangle)
Duty cycle D ~ 200ns/250us = 0.08%
Load = 1 Ohm
power = V2/R; 1002/1 = 10kW
now multiply by approximate duty cycle factor of 0.0008, and you have 8W average output power.
Based on this (unless I've made an error somewhere), it seems 98W estimated output power is very optimistic.
MarkE
Well if magpwr would install the E element, multiplier, and integrator that I have asked for, then the simulator will give us the energy and power in convenient digital form.
magpwr
Quote from: poynt99 on August 17, 2014, 09:51:25 AM
Vpeak ~ 100V
Period T ~ 250us
Load = 1 Ohm
hi poynt99,
May i ask how do you explain the 250watt x 3 bulb filament got destroyed intentionally at higher input voltage and create spike higher than 180volts which would destroy the filaments.Please produce your version of explanation which i would like to hear.This part i'm at a lost on how to explain myself. :D
Another question i pose to you -Would a incandescent bulb produce blinking effect at high frequency anything more than 18hz .Anything more than that which our human eyes is unable to detect even for fast response led. :D
MarkE
Magpwr since you have pretty good agreement between your simulation and measurement, you should have confidence that if you measure the power accurately in the simulation that you will get a reasonable answer.
magpwr
Quote from: MarkE on August 17, 2014, 11:23:43 AM
hi MarkE,
It would be pointless to explain all the needed measurements if the actual experiment don't work out. :D
There would be estimate 1 month wait for part arrival-induction heating capacitors and etc from ebay China.
In the meantime i am waiting for some parts for Don Smith China replication to wrap this up.This was my primary objective which is related to longitudinal wave. :D
Don Smith China replication original video from China which i have reverse engineered from little tips here in there in their site seen in pjkbook.pdf-
http://www.youtube.com/watch?v=vowN5BFGW1c
At this point i have completed and demonstrated the
variable high voltage power supply 150volts...1600volts in my youtube.
http://www.youtube.com/watch?v=MknH42t0IGw
