Permanent magnet OU machine working today
Started by norman6538, August 18, 2014, 09:09:28 PM
gyulasun
Quote from: norman6538 on August 18, 2014, 09:09:28 PM
I have seen today a permanent magnet only machine that has OU of 720%. 2.5 units of work were used to lift 18 units of weight.
The device can then mechanically be reset with 4 units of work such that the first cycle of lifting 18 units is repeated.
The next step in its development is automating it to reciprocate.
Hi Norman,
If you are at liberty to tell any details on the machine you have seen, please throw some bones.
Thanks,  Gyula
conradelektro
Quote from: norman6538 on August 19, 2014, 08:00:35 AMThe pendulum has OU but I have never been able to use the pendulum's mysterious energy for external use.
This happens with all permanent magnet contraptions.
But now I have enough extra to make a self reciprocating device.
All designers of permanent magent contraptions make that prediction. We do not need predictions, we need veryfied facts.
Stay tuned but it won't be soon.
Seems to be a valid statement.
I just want you to know that it is real and valid and it is being replicated/verified by a trusted colleague.
Something is real and valid after it has been verified. You are writing wishes not facts.
Greetings, Conrad
norman6538
Folks I have been benching everyday and as you see not much keyboarding.
I have made 7 versions with varying results and most show overunity - more power
out than in. But you won't believe that. A friend did view and verify that I am
right but does not have the time (just a day) to replicate one.
As I said I am working toward reciprocation which you still probably won't believe
but here is the bugaboo...
the bugaboo is the extra power needed
to reset and then start the cycle again.
I use simple units of work and they are 1/8 movement up or down
of one 1/2 washer ( as opposed to foot pounds) because it can clearly
be seen without calibration doubts.
the bugaboo defined.
ie. if 8 units of work can switch attraction on and 10 units of work is done
with that attraction and we then need the same 8 units of the 10 to switch attraction
off then  in addition we need to reset the original 8 units back where it started
to repeat the cycle  again but we only have 2  units left so we are 6 units short.
So to reiterate - the measurements show that a small unit of work can
switch on a permanent magnet and do a larger unit of work and the
attraction can be switched off so the cycle can be repeated.
There really is hope for simple visible and verifiable overunity
because I have seen it numerous times and have shown it
to a close colleague. Unfortunately he is too busy to be a significant
part of this history in the making.
Be patient with the benchers.
Norman
norman6538
Quote from: TinselKoala on August 19, 2014, 03:54:56 AM
That's right.
Hey Norman, here is an easy control experiment you can do in a few minutes. Remove _all_ the magnets around the "clock" except for the one on the rotor, and the "launch" bar magnet that you are using at the starting point, indicated in the image above.
Repeat the test using this configuration. How far does the rotor rotate? More, or less, than with all the other magnets in there?
TinselKola I won't disturb the working device to do this test but I know from much experience that what it will do is not even go up to 9 oclock because one magnet alone will slow the pendulum down. Try that yourself and you will see. Let the pendulum go for now. It simply shows that magnets do have power to do work and not get stuck...
The key question is where does that 2 extra hours of movement upward come from?
And the answer can only be from the magnets and metal arrangement. If you observe closely it appears that the pendulum is pushed along when it goes clockwise and when it comes
back counterclockwise it appears to be slowed down and even stops at 6 oclock.
Another point, the pendulum is only about 15 degrees up from flat so that the magnetic
power can be matched to the gravity power. If tilted to high or too low it will not work.
Norman
norman6538
I'm sorry it took so long but this work is very hard and slow to accomplish so here it goes.
Today I am releasing to public domain the basic principle that makes
it possible to derive usable work from permanent magnets.
The annimation is not labeled but you are seeing a metal plate that
is pivoted and lifted up by a permanent magnet and then the magnet
is pulled away without getting stuck there thus allowing usable work
from the magnet to metal attraction force.
There are many more enhancements required to increase the efficiency
enough over 200% to make it self reciprocate.
Study this well and you can add your own enhancements to make it
self reciprocate.
I have worked real hard for about a year to get this far. It all started
with what Butch Lafonte said below.
begin Butch Quote
gammarayburst:
September 06, 2013, 06:06:52 AM »
Norman, it (a magnet on wheels) will slide so easy you could push it with a
feather. Think of sliding a magnet down the side of a file cabinet with an air
  gap of .003" between the magnet and metal side. That is what I base the
  whole Pseudo Solid principle on. It won't grab on to anything till it
  gets to the end of the metal cabinet. There is no end with the bars
  in this. I have many video's showing this on youtube at the LaFonte
  Research and LaFonte Group site for 5 years now. Think of a magnet
   sliding down the front of your refrigerator door. The only reason it
    does not slide all the time is because of the friction between it
     and the door surface. Put an air gap of .003" between the two and
      watch it slide down like a rock being dropped.
Butch   end quote
Thanks Butch for that idea that started me down this path.
But what Butch never said is how to use this principle to get useful work.
So in the annimation gif you can see clearly how it is done. The bottom
metal plate is pivoted at one end so it can lift and drop at the other
end  But due to the closer stronger principle of
permanent magnets you will need a strong mounting/pivot
to build this setup. I have found that mounting the movable magnet on
a bicycle front wheel axle does well. And you will need to measure
the weight lifted by the pivoted plate.
I have measured overunity numerous times and have made a detailed sequence
that will make this a self reciprocating machine. But a warning - due to
the fact this this is a reciprocating design hughe power out will not be
possible because rotating designs can increase the rpms and get great power
but this design cannot have high rpms for high power.
Your are free to experiment for yourself with this concept but I retain the
copyrights to the idea but you are not free to manufacture and sell such a
device. I retain that right.
If you have serious interest in persuing the idea with enhancements
then email me with your background and availability.
I expect to finish the self reciprocation within a year myself. It takes
long to make such a strong and precise machine. But you should be able to
make a simple version that will get you excited about its OU reality.
See the attached annimation for the basic principle.
Norman
