The simplest motor-generator system
Started by franco malgarini, September 15, 2014, 09:56:55 AM
franco malgarini
In a motor-generator system can be used even gravity:
        output teoretico   : 1,57 KW ~ 1600Nm/sec
        input nominal/real:   ?
Salute
          OCWL
p.s.: is Ping negative in a Ping-Pong-play What is negative/positive ? Mirror-A-/Symmetrie
franco malgarini
The gravity machine works on the principle of  resonance; so that this machine can operate continuously, needs a boost that provides them to overcome the dead angle. This is achieved through an auxiliary motor intended to intervene for a very short time, of the order of tenth of a second: It is a DC motor powered directly from the dynamo.
franco malgarini
Dbowling
I cannot address the math, because I do not read Italian. Please forgive me for that. It is actually a language I am attempting to learn in my old age as my wife LOVES Italy. So I am forced to use logic to discuss what has been presented. Fix a rod to a bearing that can turn freely on a shaft. Put a weight on the end of that rod and hold the weight just to the right of Top Dead Center (TDC) and release it. The bearing will spin on the shaft (a little friction there) and the weight will swing down and back up on the opposite side. It MAY even have enough momentum to go over the top, but I doubt it. It looks promising, much like a weight on a string.
Now lock up that bearing so the falling rod is forced to rotate the shaft on which it spun so freely. What happens to the falling weight now? Add to that the resistance of the weight attempting to turn the motor as a generator (Additional resistance there). No matter how you look at this device, the motor cannot turn the weight on the end of the shaft without that bearing being locked. It is necessary that it be locked in order for the motor to turn it, raising it to the vertical,  and it is necessary for it to be locked in order for the falling weight to induce torque on the shaft as it falls.  This is far from a weight on the end of a string, and has no relation to that whatsoever. It is a lever pure and simple. Having three or four of them on a shaft if they are all aligned is no different than one large one.
Unless you have a working device to demonstrate you will never convince people like me who have ACTUALLY BUILT similar devices that did not work.
Dave
