Energy from waste heat or the environment
Started by Dingus Mungus, September 10, 2006, 03:31:27 PM
Dingus Mungus
Quote from: pese on September 27, 2006, 03:23:12 AM
@Dingus
try it with propan.
fill 2.2 atm in!
will work
pese
Well hopefully someone with the means to test this concept will give it a try in the mean time I'm focusing PMM technology. How did you determine that information?
pese
Try it ! It work.
I have "repaired" (filled) my frigidaire with them !
Old not toxid gas that was used decades before als in germany (east)
Pese
Dingus Mungus
Quote from: pese on September 27, 2006, 01:17:17 PM
Try it ! It work.
Pese
That I can understand but this concept is not relying on a chemicals ability to be used as a refidgerant but a chemicals ability to vaporize at near room temperatures. The most important aspect of any fluid that can boil at room temperature is its volume curve in ratio to H^2O steam. This is why I'm curious to how you calculated 2.2atm's of a liquid that boils at -42c would work? (I know the boiling point of the fluid increases under pressure, but how did you calculate the proper bar density)
sergio007
Dingus Mungus,
I like your idea,  :)  but I think it will l hard to make it.  to work with less friction as possible. (Needed for the less differential temperature needed between hot side and cold side to be able to run)
I think but I'm not sure if you know, do you know stirling engine ? If not they are closed loop system too. But normally they work with only vapore or air.  Somoene in near 1980 (I don't remember the name) make one that can run with only 0.5 Celcius diffence! No power output but at least it turn !  Now on the web you can easely find seller that sell it as stirling low temperature engine (with the hand only heat it run ! )
Why I talked about it is if you put some exotic gaz in it, I think with time, you will loss some gaz by the piston and by the shaft of turning door. Espacially if you have different pressure between inside your engin and outside.  If you put more great gasket, = it will be adding more friction.
Another think is I think it will be very hard to make this rotating door to be air tight, but possible with good CNC machinery. but again, you adding a lot of friction.
For the piston I suggest you to put a diaphram piston.  For rotating door I maybe suggest you to turn you disk sideway, like this it will be flat surface not curved . Like this it will be easiyer to be air tight. and to make !   ;)
In industrial use, they normally use turbine (Less friction, great effiency, lower maintenance etc.) But they need a lot a power to get great efficency, than they can not make power from waste heated water like. But I know some compagny are trying to make it with R134a like gaz but for industrial use.
Have fun !
Alp
Sergio
