tinman
Quote from: MileHigh on January 20, 2015, 09:27:31 AM
Tinman:
QuoteOkay, for starters, one thing that you have to realize is that experimentally you have an "advantage."  You do the experiment, you see it in front of your own eyes, you try different things, and it all seems pretty clear to you.  Then you give us a few sentences that are typically just results and the barest of any description at all.  Realistically, there are going to be limitations in what you get in terms of feedback and in my head I have to "invent" the setup and the details of what I _think_ might be going on and you can see all the pitfalls that happen on both sides because of that.
It wasnt my intention to give a full description of my test,i was simply stateing that i had done this very test,and i wanted to know if you knew what the outcome would be.
QuoteIf in the future you want to discuss another experiment and explore the theme of "books vs. bench" then the much better way to do that would be to make a good video clip of it.  And I have to fire a warning shot across the bow here.  No verbal description of your circuit.  If you are not willing to make a schematic for tests that involve some kind of circuit then forget it.  You probably have some old clips on your channel where you do a verbal run-down describing 10 to 15 connections and it just doesn't fly.
Are you saying that you need a full schematic of a DC power supply,AMP meter and a coil?-you wouldnt be able to follow that in a video description?.
QuoteI read Mark's comments about the pull force and the possible increased curl giving you a higher gradient close to the poles.  That might mean that there is a stronger pulling force only in close proximity to the poles.  It might mean that the attraction force dies off very quickly with distance for the "stronger" coil and for the "weaker" coil the attraction force extends out much further.  We have zero data so it's all an unknown.
Quote post 1416:  I believe the reason for this is because the field is much more concentrated around the iron coil. The field around the copper coil may well have been much larger in size-this i didnt check.
QuoteIf the difference was very minimal, then I could ignore your incorrect reference to power dissipation,
Once again,as to where did i give any power disipation meassurements for the circuit setup?. I used only P/in.
QuoteIt's like you are saying this to us:  I have two identical copper coils driven from the same voltage source.  The first coil is in series with a 10-ohm resistor and the second coil is in series with a 20-ohm resistor.  Which coil produces the stronger magnetic field?   Can you see what I am saying how that's a bullshit experiment?
No,it's not like im saying that at all. We are useing two different materials in the same configuration to see which gives rise to better results for the same P/in. The resistance is a value associated with the different materials used-nothing we can do about that if we wish to use these two different materials.
QuoteIf the currents in the two coils are significantly different, then the whole test is in a sense BS.  Yes, I am using strong terms.  It's because if you are comparing how two coils of the same geometry will produce a magnetic field, then you want to have the two coils have the same current going through them.  This is something you should know and you should have set up your experiment like this.
No No No.
When we want to know what coil will give the best results for a machine that requires a certain field strength  from our coil to opperate at close proximity to that coil for the least P/in,then the test was done correctly.
Once again-the P/in was the same.
QuoteAfter factoring everything in, the real experiment here is to test your two coils with the same current going through each coll.  Then, if you are going to measure the attraction force for each coil, you need to measure what it looks like along the axis of the coil at perhaps five or more distances from a pole.  That puts the two coils on a level playing field.
No,the real test was to supply the two coils with the same P/in,and test the pull/attraction force of each coil at close prximity.
QuoteI have to assume that when you are at a "far distance" from the the poles of the respective coils, that you will measure a stronger magnetic field from the copper coil.
As i mentioned in reply to TK's post.
QuoteBut with 20-20 hindsight it's now apparent to me that you can't do a test yourself
With 20/20 hindsight,it is clear that you decided to make assumptions about my test without knowing anything about it. For what i wanted to know,the test was carried out correctly,and gave me the exact results i needed to know. And to say i cant do a test correctly,and base that assumption on incorrect assumptions, is the BS you are after.
QuoteMy final thought which I think you avoided is to go back to the permeability issue.  That is sound and makes sense and I thank Mark for mentioning it.  If you did a proper test setup like I mention above, I am not talking pull force, I am talking doing a compass test or something like that to see which field is stronger.  Will you feel a stronger attraction force up close for the iron coil?  What Mark said about the curl sounds plausible.  I would measure the forces and also do an iron filings test to look at the curl and gradient of the magnetic fields from the two coil.
The test setup was correct for the information i required. I have already agreed that the magnetic field from the copper coil was probably much larger,and the iron wire would have concentrated the field around the coil.
tinman
Quote from: verpies on January 20, 2015, 03:15:59 PM
QuoteNo, kilogram is not a unit of force.
1kg is equal to 9.81N,and newtons are a messure of force. Is this splitting hairs? or are we to stick to the !1kg is an amount of mass that exerts a force of 9.81N on the earths surface?!.
Seems to me that saying 1kg of force is exactly the same as saying 9.81 newtons of force when used here on earth. This would however change in space where there is no gravity,as you can have mass but no weight.
verpies
Quote from: picowatt on January 20, 2015, 04:59:02 PM
As I said, I could be wrong, so hopefully someone will comment a bit further and better than I...
MarkE?  Verpies?
You can interpret the Tesla in so many ways, it's not funny.
...and don't forget the Xavier Borg's blog while you're at it  ;)
verpies
Where:
m = meter
s = second
kg = kilogram
A = Ampere
V = Volt
C = Coulomb
J = Joule
N = Newton
H = Henry
Wb = Weber
tinman
Quote from: ramset on January 20, 2015, 11:26:42 AM
TinMan
Some light reading directly related to misconceptions  . And perhaps a method to harvest energy
From some heretofore difficult venues....?
http://bovan.net/gmweb2/The%20FS%20Loop.htm.  (From a friend of Yours )
Enjoy
Chet
Just started reading this Chet,and im hooked already.
How true is this book.
1 verse-quote:
Also, most folk seem to forget that when they are but one in a crowd of like minded and consensus deriving thinkers, everyone still has individual and personal responsibility for what they themselves believe, and thus for all of their actions which result from their beliefs, whether these appear to be majority determinations or not.  Yet whilst some individuals do not know what questions to ask in order to develop a fundamentally correct comprehension, or are maybe unwilling to be recognised for being seen to ask an important question which might upset many egotists or activists within their group (yes, even in science), with the result that many follow blindly without asking or thinking, or accept that they ought not ask when told to not do so, no one can achieve a usefully realistic understanding without provision being made for the answering of each and every question posed.  So in relation to formative learning, we ought not rely solely upon explanations provided exclusively by the hierarchical and subjectively imagined hypotheses which led to the development of qualified "expert" opinion, but instead strengthen foundations by building upon irrefutable findings via the objectively established and openly truthful reporting of observation and occurrences, also repeat testing, demonstration and experimentation, such that we might beware a collection of isolated facts becoming joined together in a manner which misrepresents fundamental truth, due to our minds having been conditioned in a manner which makes it difficult to see beyond any 'power presentation' of anything we are told;  as especially with relation to the fundamental nature of electromagnetic-radiation itself.
Lets await the onslaught.
