Crystal Cell Research for Experimenter
Started by plengo, October 24, 2014, 11:36:59 AM
tgraca
Quote from: plengo on December 10, 2014, 12:47:16 PM
I was convinced that the power coming out from those cells was not only galvanic.
Now, you should see a clear pattern where the one that is watered most frequently is the first to die in total corrosion before the rest
but it will not be the one giving the most power ration in relation to length of life. The one with the least frequently water added will be
living MUCH LONGER useful life and power ration in relation to life length.
In other words, the one that receive the least amount of water/Epson will be the one giving the most amount of power AND life much,
much longer than the rest to the point that you will notice that EVEN ADDING the life length of the first 2 it will still win.
Fausto.
Before cell #344, I had made about 20 wood glue cells with 50/50 borax and sea salt. I am still testing this in the way you described.
I accidentally break off the single mag strip once in a while, which to means the cell is volunteering to be dissected, so I oblige. I don't
see any deterioration on the mag strips or copper, unless I accidentally put the salt/borax near the copper or mag. For most of these
cells, I put some tissue between the salt and glue, but for the others, there was some deterioration. More watering and use made those
deteriorate, but not the others. So, insulating the electrodes is key. This is the purpose of making a semiconductor on the electrodes,
but from my experience, you can do this without cooking...
Also, with constant use, they tend to give little power after a few days or a week, but if I let them sit for a day or a week, they come
back to full power. I am not sure if this is what you are looking for, but I have seen this in many many many of my other 300+ builds
too.
I think these are 2 separate issues - galvanic or not, these cells come back to life with a little rest. My goal is to retard the galvanic
process for at least 6 months with constant use. When I get this, a simple solution to giving them daily rest periods is to add a light
sensor circuit to turn them off for about half the day. This will make the cells last probably twice as long, so now we are talking at
least a year before any rebuild is necessary, but the circuit build is a pain.
I am still looking for a simple solution for a light sensing circuit. There are photo resistors that have an open resistance of less than
1 ohm, which would be what I need, but they are relatively expensive. The ones I have start at around 4k to 5k ohms... even with
tuning, they aren't sensitive enough to shut the circuit off with very low light, or even moderate light.
So, I think I have proved what you are saying about these cells coming back to life and I am on the right track since they all work
as you described, except I don't think the galvanic effect is is a separate issue.
plengo
Quote from: tgraca on December 10, 2014, 01:36:30 PMFor most of these
cells, I put some tissue between the salt and glue, but for the others, there was some deterioration. ...So, insulating the electrodes is key.
This has to do with the "room" for crystal growth. Putting paper, separators, isolators, none will work really. The two things are invisibly mixed, the reduction in corrosion but also in power and crystal space to growth. One has to envision a test to distinguish the two.
QuoteAlso, with constant use, they tend to give little power after a few days or a week, but if I let them sit for a day or a week, they come back to full power. I am not sure if this is what you are looking for, but I have seen this in many many many of my other 300+ builds too.
This IS what I talking about. I call it dormancy period or state. This is a proof that corrosion is not the only thing here. Use that as a guidance for the fine tuning of your "formula".
Fausto.
tgraca
Quote from: plengo on December 10, 2014, 01:46:01 PM
guidance for the fine tuning of your "formula". Fausto.
I talked to Peter Linderman earlier this year and he gave me his opinion on this, with which I agree. I hadn't thought of it before, but these
cells are partially a thermo electric generator. To test this, I took four of my similar cells that were exhausted from constant use, put 2
exhausted cells in the fridge, and left 2 in room temperature. I took one from the fridge and one at room temperature and hooked up them
up to JT's. They both worked, but the one from the fridge wasn't near as bright and couldn't get it's act together until I finally left it
disconnected from a load for a day, then it came back to life. For the other two, I let the one from the fridge sit for a day and then hooked it
and the last one that had been sitting at room temp up to JT's... the fridge cell had more power than the one from the last test, but it
was no match for the one that had been sitting without load at room temperature for several days.
Bedini has a video of a carbon / mag strip battery - a LidMotor replication - he explains that it is not a galvanic cell, but rather a thermo
electric cell and showed a few degrees difference in temperature between the mag strip and the carbon rod... So, I think that's what's
going on here when there is no galvanic effect.
The MnO2 will give that effect, and possibly the activated carbon, but I get this with all most of my electrolyte mixes, and I am not sure
if this is coming from the crystals or the electrolyte or the electrodes or some combination of those 3 things. Interesting!
PS - LidMotor was calling it an air battery as I remember.
plengo
Quote from: tgraca on December 10, 2014, 02:03:11 PM
It is interesting. Create a new test to prove their theory. Create a cell with LOTS of paper around the Magnesium. All the cells with exact same formula but change ONLY the geometry. Report what you will find.
I bet the one with most "space" between the electrodes and lots of "crystals" will work better.
Thermo!!! Hmmm, why my videos where called "Thermo Static cell" ??
Fausto.
tgraca
Quote from: plengo on December 10, 2014, 02:36:40 PM
Fausto.
Actually... cell #359 has a ton of coffee filter in it and it is very weak. I'll figure a more controlled test... not sure if I will get to it today...
I am working on an easy way to log AND review the performance of multiple cells IN DETAIL and don't want to start more until I have
that done. I guess there is no interest in the application... I have to work it out with paper first anyway... I think a tac and small 2" x 4"
clip board next to each shelf is the way to go at this point... notepad isn't working for me anymore...
I thought you called it Thermo Static because you were cooking it with electricity... I don't think "static" describes thermo "electric",
but I could be wrong...
http://en.wikipedia.org/wiki/Thermoelectric_generator
http://dictionary.reference.com/browse/thermostatic
