Crystal Cell Research for Experimenter
Started by plengo, October 24, 2014, 11:36:59 AM
ramset
Do you fellows understand that the 1mil sheet can be opened and examined for Galvanic reaction
and if Fausto has touched on a mechanism to harvest with no input power and if this mechanism is found to not be ambient noise harvesting ?
the Keys to a much bigger city !!
Masterplaster mentioned Titanium Dioxide coatings with Water and Glass
these "aligned chain" water molecule configurations ...are all the rage these days
here the Vid again from applied science.. the 9 minute mark shows Glass harvesting charge from Water [nano scale] with no power
https://www.youtube.com/watch?v=zzVa_tX1OiI
and we can experiment here ??
nothing but gratitude and Hugs for the messenger !!
Thanks Grandma
https://www.google.com/search?q=marcus+reid+cristal+cell&ie=utf-8&oe=utf-8&client=firefox-b-m
www.breakthru-technologies.com  11 mW/Kg/25°C
if this is the per hour delivery :
11mW x 8766 hours ~ 96,5 Wh/Kg/year
compared to 1999-2006 10 Wh/900 Gr/year
96,5/( 10/0,9) ~ 8,7  the output or 770% improvement  !
32850 Kg /8,7 ~ now 3775 Kg cristal cell material for 1 KWh per day electricity delivery ~ 1 cube metre
Here the Reid cell development company :
https://vakuumenergie.de/?by_user=66.249.66.140&ref_url=%2Fdoc%2FThe_Crystal_Cell.pdf
Economical-/ecological view :
3775 Kg and 1 KWh( 41,5 W x 24 h)
compared
12 V and 1,5 A = 18 VA x 24 h = 432 VAh or Watth per day
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=5&ND=3&adjacent=true&locale=en_EP&FT=D&date=19280203&CC=FR&NR=633752A&KC=A#
Weight/portability dis-/ad- vantage. ? Production costs  ?
3x Meredieu capsels ~ 1x 3775 Kg Reid cell cube
Meredieu disadvantage : the periodic water as ionic fuel refill
skywatcher
Quote from: ramset on November 11, 2019, 03:11:53 PM
Has this been done ?  If yes, and there were no signs for galvanic reaction, this would change my mind.
The problem is: the average experimenter (without a deep understanding of chemistry) is not able to do such an examination. This has to be done by a lab.
ramset
Skywatcher
Accounting for ...or auditing all the energy from assembly /manufacter time until years later invasive/destructive analysis ?
I am certain data logging the output at maximum load
Long enough to make obvious galvanic particulate trace (if that is part of analysis
Protocols ) in conjunction with energy output audit (for sample comparison against galvanic "control" cell
Of similar/same composition and weight size etc (within reason?)
Can very easily be done !
Member Gotoluc recently did this for 3 or more months with an "Attempt " at a Rick Freidrick battery
Conditioning claim (no magic found tho in comparison to standard batteries ( as of this writing ...that
One may still be ongoing ...not certain)
Fully automating test apparatus with arduino or similar for autonomous data logging  (set test protocols ??
Below entertainment /education??
Charge can do funny things ....here an unrelated (or is it) vid of a guy showing just how odd a charge
Effect may be (energy field)
From member Jim  Boot https://m.youtube.com/watch?v=I2B6j4MCpOg&feature=youtu.be
Thanks Grandma
skywatcher
The problem is that most of the crystal cells deliver so little power that you have to wait for years or even decades to rule out galvanic reaction.
Also the 'they don't die when shorted' argument is problematic because they have a high internal resistance so you can not really short them externally.
@Plengo:
How do you 'treat' the surface of your electrodes ?  I didn't find any info about this in your videos.
To replicate your results every detail how you make them is important.
