GDS 3 KW generator runs on water
Started by ramset, October 25, 2014, 09:24:26 PM
synchro1
Quote from: MarkE on December 04, 2014, 04:04:50 PM
Synchro1 read what you just wrote:  "The US Navy makes fuel this way."  Neither the water nor the carbon dioxide feed stocks are fuel.  They are feed stock to a process that makes fuel out of those feed stocks by using a lot of energy.
I don't know what you are on about with the RCMP.
Here is something to think about:  Are hydrocarbons the ultimate hydrogen storage mechanism?  Suppose that one had a convenient and low-cost way to capture tail pipe CO2.  Suppose also that one had a: clean, plentiful, and cheap source of electricity.  One could then take advantage of the advantages of liquid fuels without having to pull oil from the ground, or dump net CO2 into the atmosphere.
All you need to do is find an extension cord long enough to reach down to the carrier from an altitude of 30,000 feet! Try burning potash by focusing high frequency broadcast radiation at it!
Quote from Kookcooala:
"Take some white ashes from your fireplace. Get some more energy out of that, why don't you? Nobody would even try, they know it's a waste of time".
JDHardy54
To those who believe and hope someday we will have free energy!!!
This guy is not going to change the world,, I can guarantee you this guy is out to steal your money.
I have posted on this site, to wake up people that believe and hope in this guy.
I have built this machine years ago and it does not last I don't know how much more I can say.
There is no secret behind his generator it is straightforward very simple for most people to understand.
James Hardy
Quote from: Nink on December 04, 2014, 04:19:06 PM
If you attach a wind turbine to the roof of your electric car will you charge your battery as you drive along so you can drive further?
If I put a Pelton wheel in front of my electric water pump can I use the energy crrated to ruñ the water pump.
If I convert water to HOH can I use the hydrogen gas to convert more water to HOH?
Yes you will generate energy from all these examples but the energy created is less than the energy used to create it.
I can't believe we continue to have this discussion
I can believe it. Look at how reasoned, factual responses are met with insults and foot-stomping. Consider the source...
Cap-Z-ro
I will say it again...nobody knows whether the generator has been modified.
For example, look at the thread about the lensless generator...who's to say he hasn't done something similar with his  generator ?
Regards...
synchro1
Quote from: TinselKoala on December 04, 2014, 05:54:45 PM
It's more correct to compare salt water to crude oil then it is to compare it to potash based on the arguments you're citing.
