GDS 3 KW generator runs on water
Started by ramset, October 25, 2014, 09:24:26 PM
MarkE
I use FF 32 with the no script add on.
gotoluc
Quote from: MarkE on October 27, 2014, 11:27:21 AM
Okay, I added no script add on to firefox and the links are now working
thanks
Luc
Quote from: tinman on October 27, 2014, 10:49:26 AM
If i use IE,i see what Luc see's,if i use firefox,i see the add that TK see's.
@TK
The pelton wheel is powered by the water pump at the bottom corner of the water tank.
That's hilarious, completely hilarious. He combines several lossy systems in series and magically attains OU.
Pelton wheel: up to 92 percent efficiency for the most modern sophisticated designs.
PMA: up to 90 percent efficiency.
Motor driving water pump: perhaps 85-90 percent efficiency.
Water pump hydraulic efficiency: perhaps 90 percent for the very best designs.
0.92 x 0.90 x 0.90 x 0.90 = about 67 percent throughput efficiency. Where is the OU magic coming from?
ramset
Tinsel
I know you have done hundreds of similar experiments ,,,
No?,,,well dozens maybe......
Ohhh.... a couple......?
No...?
Not even One ??
Oh I see,   To smart for that kinda stuff.
I'm running around seeing doctors today ...
I spoke With Mr.Potter this AM will post more here and elsewhere Later.
thx
Chetkremens@gmail.com
Thanks Grandma
Quote from: ramset on October 27, 2014, 12:29:19 PM
Tinsel
No...?
Not even One ??
thx
Do you seriously think I report _all_ of my work here? Yes, I have made Pelton turbines, gnawed them out of aluminum or plastic with my own little teeth. Yes, I have worked with commercially available Pelton wheels like the one attached to the PMA. Yes, I have connected them to generators and even directly to pumps. Please do not forget that I was actually gainfully employed, full time, doing work researching devices like this one, in Canada, for around ten years. Very little of that work has been reported here, of course, since I was under NDA.
Now... You? Ever worked with a Pelton turbine driving a genset driving a motor driving a water pump?
Good luck with the doctors.
PATENT NUMBERS PLEASE.....
