Ufo propu engine, closed loop
Started by ingyenenergiagep, November 07, 2014, 01:34:16 PM
ltseung888
The suggested dimensions in reply 100 are changed as follows:
Old suggestion:
The suggested dimensions are:
1. Ferrite-rod core diameter   5 cm
2. Length of triangle   20 cm
3. Diameter of copper wire   2 mm
4. Number of turns of wire    1,000
5. Height of Cylinder   5 cm
6. Width of triangular plate  2 mm
7. Size of Guide Hole   1.5 cm
8. Diameter of Guide Rod  1.3 cm
9. Length of each Guide Rod  1 m
10. Voltage of DC Current can vary from 1 to 30 Volts (adjustable)
New Suggestion:
2. Dimension of rectangular plate   24 x 30 cm
5. Height of Cylinder   7.5 cm
6. Thickness of rectangular plate  2 mm
7. Size of Guide Hole   1.5 cm  in diameter Center of Hole 2 cm from edge
9. Length of each Guide Rod  1 m (2 needed)
11. A wooden board of diameter 30x24x2cm is needed for the base
The changes in dimensions are due to:
1. Use of two Guide Rods rather than three
2. Final shape cut from a rectangular plate
3. Some room left for the non-perfect tightness of winding.  7.5 cm length allows for 37.5 turns of 2 mm wire(perfect case).  We now assume 33 turns.  We allow the number of layers to be 33 giving 1089 turns.
4. The width of the rectangular plate is 24 cm.  That should be sufficient for 5 cm of ferrite rod + 7.5x2 cm of coil space with 2 cm on each side as spare.
5. The length of the rectangular plate is 30 cm.  That should allow enough space to drill the Guide Holes.
6. The cutting away of the triangular pieces to produce the figure in reply 101 is optional and is for reduction of unnecessary weight and looks.
Lawrence
http://www.overunityresearch.com/index.php?topic=2100.msg51962#msg51962
ltseung888
The three lowly, smelly workers were at work again.  Another idea came up.
Two separate experiments will be compared.
Case 1 uses two air coils.
Case 2 uses one air coil on top of a Ferrite core coil.
In Case 2, the air coil is expected to jump many times higher with approximately the same Input Electrical Energy...
Both design 5 and design 6 experiments should be done.
*** I expected such experiments have been done by the USA and Chinese Military Research Institutes.  If not, they can do it easily.  Other Nations or Universities can do it too.  If COP is found to be greater than 1, lead-out energy will be accepted.  The New Paradigm begins...
*** Can the USA and Chinese Governments still keep the top secret???
Lawrence
ltseung888
https://www.youtube.com/watch?v=5yPwi-jC9lI&index=25&list=PL65685704949FE0D6
Some soothing music...
The progress of the World will not stop.  After the electric light, no one will go back to candles.  After the Internet, no one will go back to telegraphs.
Once lead-out energy flying saucers is understood, no one will travel on airplanes...  The young and coming scientists and engineers will overcome the road blocks,  Some will do the experiments and succeed...
It is a matter of progress and time.
*** One Interesting comment at a Nursing Home:
Person A: "Doctor, if the patient cannot be cured, what is the point of prolonging his life and suffering.  The family suffers too."
Doctor: "My training and my job is to keep the patient live as long as possible."
Person A: "But the patient is old.  He is of no use to society any more.  He is a burden.  He needs someone to feed, wash and clean him.  What is the point of prolonging his life and his suffering?"
Doctor: "That is a moral question.  He and the family can legally refuse life-support systems.  But if he comes to the clinic or hospital, it is my duty to prolong his life."
Person B: "He or his family can refuse clinic or hospital care.  He can choose to pass his remaining years at home."
Person A: "That is not possible.  He needs someone to feed, wash and clean him.  The burden on the family will be too great."
Person C: "Long life is no longer a blessing..."
When one has something to say, to do or to share, TAKE ACTION.  That something may not be perfect (or even correct).  But trust the Almighty and TAKE ACTION.  Sow seeds and some will fall on fertile soil...
China and USA governments will not be able to keep the top secret for long...
Lawrence
ltseung888
The three lowly, smelly workers again.
The force due to circular motion is m*v*v/R.  Is it possible to vary R?
ltseung888
Quote from: ltseung888 on September 24, 2015, 03:31:15 PM
Yes.  There can be many design variations.  One is having the magnet at the end of an extensible rod pushing on smaller R on top.  That would also provide net thrust towards top.
Anti-gravity can be this simple...
China and USA Military Establishments should have no problem designing and building UFOs.  When will they disclose the top secret?  Are they waiting for some other Nation to announce it first???
