Ufo propu engine, closed loop
Started by ingyenenergiagep, November 07, 2014, 01:34:16 PM
ltseung888
@Tseung
Can you define what you understand by the UFO technology?
ltseung888
Quote from: ltseung888 on February 09, 2017, 04:36:07 PM
@Tseung
(1) UFO is commonly known as the flying saucer. It has the characteristics of making sharp turns, hovering, moving at high speeds and vanishing into space.
(2) To produce sharp turns, a flying object can have thrust in the 90 degree angle of the flight path. This is well understood.
(3) My understanding is that the thrust can be generated internally without ejecting any hot gases. That process is sometimes known as inertia propulsion. I believe that a magnet moving at different speeds in its circular path inside the UFO can achieve that.
(4) To hover in air, a helicopter has to make air above the blades move faster than that below. With a spinning object, the right shape can do that. For example, the top side can have wave like structures to generate high speed motion. The bottom can have shapes to produce turbulence and thus higher pressure.
(5) In conventional jet aircrafts, hot gases are ejected out. Much fuel must be carried on board. If inertia propulsion were used, there is no need to eject hot gases. The source of energy is not absolutely clear to me yet. But some experiments point to the use of the full electromagnetic wave spectrum. Solar panels use only a tiny portion. The Milkovic 2 stage pendulum points to the possibility of using gravitational energy. If that were true, the unbalance Chan Wheel should be more efficient.
Hope the above helps. I believe China, USA, Russia and some other Nations have developed flying saucers already. The most interesting aspect is the energy source. Some claimed that zero point energy was used...
ltseung888
http://www.selectabroker.com/Macau/
There are over 150 Forex brokers listed in the above site. Macau, as the World's Number 1 gambling center, allows liberal Forex trading. China may use Macau as a base for a "Regulated State Forex Exchange". Chinese citizens may be allowed to trade there...
ltseung888
Quote from: ltseung888 on February 09, 2017, 04:23:04 AM
Stop loss activated. Loss around HKD8K.
Wait for 6.8650 before another sell order. This is the safe route - stop loss and repeat deeper in the resistance range.
Trying out another strategy. Put in a sell order. This means that we have two opposite orders cancelling each other out. I can rest at peace no matter how the market moves. The plan is to get deep into the resistance level. If the rate keeps rising, there will be no more risk. Can wait until a very high level. When the rate falls clearly, take profit on the long side. Let the short side take advantage of the downward trend and profit.
Actual figures:
Short the pair @6.8643 No stop loss.  Aim to take profit when the pair drops to 6.8123. Profit 520 PIPs.
Long the pair @6.8709 No stop loss. Total unrealized loss = -7,200. Aim to hunt for the top resistance level totally risk free. (Will have to pay some premium.)
*** When top presumably reached, short again at that level.
ltseung888
Quote from: ltseung888 on February 10, 2017, 03:44:47 AM
Actual figures:
Next time, enter the short and long at approximately the same time. The trransaction cost will probably be twice the spread or 38 PIPs (approximately HK$3,000). When guessed right, the profit should be in the region of $20,000. (If doubled at the new level, the profit should exceed 40K.  Not bad.
Is it a low risk strategy? The timeframe for each trade is likely to be one to two weeks.
Earning $30K per month on capital of $200K should not be a problem. Growing the capital to $400K in 6 months with this technique appears feasible. Let use see.
*** This Forex Trading is extremely addictive. One can trade both in up or down market. One can trade 24 hours a day, five days a week. (Need two days to rest.) There are many strategies that can be used.
