Ufo propu engine, closed loop
Started by ingyenenergiagep, November 07, 2014, 01:34:16 PM
ingyenenergiagep
ltseung888
This post is a continuation of the discussions from
http://overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/new/#new
The ninth design of the Flying Saucer is reproduced here.  It is likely to be discussed thoroughly before implementation at various academic institutions.
The theory is King David Sling Technology.  When the magnet moves in a circular path, it experiences a Centrifugal Force away from the center.  The faster the angular velocity, the higher will be this force.
The invention gives energy to the magnet at the top part and takes out energy at the bottom part.  THe difference in Centrifugal Force provides the net thrust.
Lawrence
http://www.overunityresearch.com/index.php?topic=2100.msg50206#new
ltseung888
Had a good meeting at the mechanical engineering department on turning the lead-out energy fling saucer project into student projects.
Peter Chan delivered his Chan Wheel a day earlier.  Lawrence Tseung brought the Joule thief prototype with capacitor.  Both devices will be at Hong Kong University for sometime.
The focus was the various small projects the student can reasonably perform.  The preliminary list is as follows:
1.  Use the vertical tube magnetic repulsion experiment with air core, ferrite core, partial air and partial ferrite core and additional magnet to check the Input and Output Energy.  The Input Energy is the pulsed DC electrical energy that can be accurately determined with the Digital Oscilloscope.  The Output Energy can be determined by the height of the magnet reached inside the transparent tube.  This experiment can determine whether Output Energy can be greater than Input Energy.  If so, there will be great encouragement to the students and the team.
2.  The QMOGEN experiment with an unbalanced wheel to increase the torque.  Since over 60 QMOGENs have been reported to be successful, this will be an additional confirmation.  There are at least three groups in Hong Kong rumored to have achieve success.  This will be a further confirmation that energy can be lead-out.  The US patent will be examined in detail.
3.  The accurate determination of when to apply the pulse and for how long.  This may be the most difficult experiment.  Peter Chan had done much work in control systems previously.  He will prepare the material for a full presentation when ready.
4.  The building of the Unbalanced Wheel with one or more magnets at the rim.  Since the Wheel will be unbalanced, much shaking is expected.
5.  The use of Drive Coils.  The number of turns, the gauge, the DC voltage etc. need to be researched and determined.  Much can be gained from the experiment in 1.
6.  The use of Collector Coils.  One of more Collector Coils may be needed.  Their construction and positioning may be different from the Drive Coils.
7.  Feeding the energy from the Collector Coils back to the Drive Coils.  This may be the crowning success.
8.  The complete Flying Saucer propulsion unit.
9.  Other control and improvements
At present, the focus will be on experiment 1.  Planning work can be done now.  The actual experiments  by the student will not start until after the summer holidays (late September 2015).
Lawrence
ltseung888
Quote from: ltseung888 on July 08, 2015, 07:17:47 PM
Important comments:.
1.  The Input Energy can be measured accurately with the DSO.  The exact waveform of the voltage and the current can be captured.  The time can be determined.  DSOs are standard tools at Universities.
2.  The Output is the simple mgh.  The mass of the magnet m; the height reached h can be accurately measured. It can be captured on video.
3.  The Output energy may not be more than the Input Energy in all cases.  In particular, the air core case may not show this effect.
4.  However, if only one set of reproducible output greater than input can be shown, the impact to the academic world will be significant.  Lead-out energy may get recognition.
5.  The magnet can have large mass if it were to be used in the Flying Saucer.  It can be up to 1 Kg.
Lawrence
ltseung888
Refer to reply 2 of this thread.
Should we do the straight tube magnetic repulsion experiments before the Students?
Prof. "For undergraduate projects, this is the rule.  Undergraduates are expected to repeat experiments with known results.  They are not expected to innovate.  They are expected to learn and master known techniques.  Postgraduates are different."
Tseung: "We can give part of the project to undergraduates and other parts to postgraduates."
Prof. "That is in line with my thinking."
Tseung: "We shall plan on doing the vertical tube magnetic repulsion experiment ourselves before the students.  I have the Atten Oscilloscopes; I can also buy the magnets, coils, ferrite rods, battery etc.  I shall let others shine.  The technique to train the young fisherman is to provide the equipment, show how to catch one fish and provide lots of encouragement."
Others can do this simple experiment also.  Any organization with DSOs anywhere in the world can do it.  Proving overunity or leading-out energy is this easy.
If the potential energy output can be demonstrated conclusively to be more than the electrical energy input, overunity will be proven beyond any shadow of doubt.  Lead-out energy theory will be recognized.
Is it possible for USA and China to keep the top secret?
May Divine Guidance show us the way....
Lawrence
