Ufo propu engine, closed loop
Started by ingyenenergiagep, November 07, 2014, 01:34:16 PM
ltseung888
Some amazing results when we use the average V*I analysis method.  Waveform expanded by Paint for ease of analysis.
Note that the current (voltage across an one ohm resistor) =0.2A  when the Voltage registered 68.8V.
That single result (back emf?) produced the unexpected high COP.
ltseung888
Reply 301 is incorrect.  There is no need to focus on the leading edge.  The time interval interested should be around 50ms and not 5ms.
ltseung888
Experimental Result using 4 Magnets for Jumping
The COP value improved from 1.5 to 1.94.
The experience so far indicates:
1.  Use more turns (300 and up) produces higher magnetic repulsion.
2.  Use more magnets (up to 4 tried) increases both m and h.  Higher mass and higher jump.
Both points increase COP significantly.
More experiments will be done to gain more knowledge and experience.
Overunity is confirmed with the setup and assumptions.  Will encourage more people to replicate.
UFOs are flying.  Many are USA and China Made.  Will they disclose the Top Secret?
Divine Wine is for all to share... Love Thy Enemies...
guidoc66
Hello,
simple question: the time base in the dso pictures looks to be 100ms; if one square is 100 ms then the pulse duration should be around 250 ms
Why did you mention 50ms?
thanks
guido
ltseung888
The circuit.
One common mistake was ignoring the common ground between the CH1 and CH2 scope probes.
Once that is connected properly, it is easy to see that the CH1 (current) waveform should be inverted to show proper display.
