The new generator no effect counter B. EMF part 2 ( Selfrunning )
Started by syairchairun, November 09, 2014, 09:05:00 AM
I have done rather extensive experimentation, fifteen years ago, with the Siberian Coliu as described by Marinov and his mentor Nikolayev. I have actually seen a full copy of the rare book (in Russian) by Nikolayev where several interesting configurations of magnets are described. Jeffrey Kooistra, formerly Gene Mallove's (r.i.p.) assistant at Infinite Energy Magazine, tested such a configuration that he called the "Warlock's Wheel" and described the most interesting behaviours that he noted. These are so very unusual that many authors of papers on the Siberian Coliu, like Kelly, have either dismissed them as fake or don't even discuss them at all. But they are not fake, they are real. Sadly, in contradiction to Marinov and Nikolayev, these effects (which I have described elsewhere and which Kooistra also clearly describes) DO depend on ordinary flux leakage from the split magnet structure used as the rotating armature, and not the surrounding A-field. If anyone would like to dispute this statement of mine, please feel free to _demonstrate_ with your own carefully constructed Siberian Coliu motor.
Meanwhile, my Marinov Slab pulse motor simulates part of the system, translated into a continuous-rotation pulse motor, which (apparently) does NOT show the usual "armature back reaction" of a typical motor. That is, the rotor experiences an accelerating force which causes its rotation, but the stator structure doesn't (seem to) experience an equal back-reaction in the other direction.
FreeEnergyInfo
Enjoykin
Quote from: Dog-One on November 18, 2014, 03:36:39 AM
Always something new around the corner.  Thanks for the explanation and images.
Hello Dog-One  :D
"The existence of longitudinal force is contrary to the laws of electrodynamics. This force is the result of the scalar magnetic field present at the site of cut magnets. Such a composite magnet called SIBERIAN COLIA."
I think correct formulation should be "The present laws of electrodynamics are contrary to longitudinal force".
Why ??
Because Scalar field is primary and real existing entity while " laws of electrodynamics" are nothing more than fiction of human mind.  :D
Expressed by a formula of Professor Dr.Genady Nikoalev longitudinal force is:
F= = H* I
H* is Scalar Magnetic Field and is divergention of Vector Potential A. Hs* = -divA.
I is current in the wire - vector.
Simple experiment which have done R.Sigalov is clear proof of existence of longitudinal forces.
It is a simple П frame contour with sliding contacts and current flowing through it. We can see that П frame contour is running at right side only by action of longitudinal forces. Direction of longitudinal forces is along conductors 2 and 4. In full correspondence with law of conservation impulse,  transverse force is append to conductors 1 and 5. This is experimentally fact which can repeat anybody. This fact can't be explained on other ways but only with existence and action of longitudinal force caused by H*= Scalar Magnetic Field. In zone of sliding contact at conductor 1 Scalar Magnetic Field H* will be positive while in zone of contact at conductor 5 will be negative. Because currents in conductors 2 and 4 are in opposite direction - longitudinal forces will combine together and make action in one direction pushing П frame contour to the right.
Reg.enjoykin
Enjoykin
Quote from: TinselKoala on November 18, 2014, 01:28:00 PM
Hello TinselKoala  :D
In above experiment where is famous " flux leakage" from splitted magnetic fileds caused by flowing currents ??
Clearly there does not exist any " flux leakage" just like the same in your case. Effect was caused by Scalar Magnetic Field H which was caused by vector potential A. There is big difference.  Scalar Magnetic Field H* is not the same thing as Vector magnetic potential A. Vector potential is the source of Scalar Magnetic Field  H*not contrary. In my visualisation A is helicoidal stream of particles flowing through the aether.
Try finding and analyse patent of Hogan-Jakovlevich from 1950 with configuration of two Siberian Colia magnets rotating in opposite direction on same axis while basket weave coils are put between. To give you a clue - same is happened between plates of bipolar capacior under influence of alternate currents. Scalar Magnetic Field  H*was produced and flowing between capacitor plates. I said this because the same configuration had used L.Hendershot in his generator. Also in Mislavsky transformer !!
ps: I want to ask you if you have any interesting ideas about Scalar Magnetic Filed detector(s) ?? As i can conclude from your posts you have very much experience in electricity artwork!!
Reg.enjoykin !! :D
ARMCORTEX
If anybody can find the measurements in details of the st series synchronous motors that would be great.
This needs to be made smartly and modular, precise to the motor itself.
I have just learned myself cad in the last few months
