The new generator no effect counter B. EMF part 2 ( Selfrunning )
Started by syairchairun, November 09, 2014, 09:05:00 AM
Enjoykin
Hello l0stf0x
I think it is good starting from some "simple" configurations.
Basic building block is Siberian Colia magnet. These are original concepts made by Dr.Genady V. Nikolaev. Main stuff most important is shielding Vector magnetic field B because it is OU enemy. Than you make several building blocks you can start further with simple experiments. S field can't be shielded but is present in same time with B field. Below is simple picture of Dr.Marinov S-machine (Siberian Colia Motor). S machine can work as motor or as generator.  Siberian Colia Magnet is Magnetic Quadrapole. S field can be positive or negative sign - same as B field.
Reg.
ps: What's happened with Syairchairun ??
Before several days he told me that he plan to present in public his Magnetic Configuration !! Also he told he has special magnetic configuration deep in his soft-iron rotor. In his case sof-iron rotor is B vector shield. Between stator and rotor should be as small air gap as possible. Also configuration and position of coils is very important.
T-1000
Quote from: Enjoykin on November 21, 2014, 05:58:12 AM
Hello l0stf0x
Hi,
The build you are describing involves scalar magnetic fields and this is completely different than was shown in video of first post.
Perhaps you can make different thread with all proposed designs or add it to http://www.overunity.com/14691/the-marinov-generator ?
T-1000
Quote from: l0stf0x on November 21, 2014, 04:32:08 AM
Hi Enjoykin, I just saw your mesage..  I was ready to post some drawings on my new thinking..  please check it
(24 poles - 3 phase coils)
The magnets should be all same ploarity in all raws and also you do need only middle magnets with air spacing from the sides... The coils are same over entire height and added magnets with different polarities at same time won't help much with induction.
Enjoykin
Quote from: T-1000 on November 21, 2014, 07:49:13 AM
Hi,
What are you thnik - Who you are?? Why trolling my posts here ?? Another Amerian agent at this thred ?? Do you think it is easy jumping from one thread to another and disinform people which want to learn something new ?? And how do you dare to command me to go to another thread and make my posts there ??
Did you fallen from Mars ?? Or any other planet ??
I said and can confirm (and not only i). You also have confirmations of Dr.Marinov, Dr.Nikolaev and many real physicist (not main stream official liers) that:
THE ONLY WAY TO MAKE PERPETUM MOTION S MACHINE IS ONLY WITH THE HELP OF SCALAR MAGNETIC FIELD !! THERE DOES NOT EXIST OTHER WAYS !!
And i have not time to make stupid games with governements trolls here or everywhere !!
Clever man will take good advice from next text of Dr.Stefan Marinov.
From letter Dr.Marinov to Dr.Nikolaev
All point is that equation of Lorentz "go to pieces". Cylidrical magnet cutted at half in axial plane with one half rotated 180 degrees, make in vicinity of slit magnetic filed which operate on currents with longitudinal forces. According to equation of Lorents forces which magnet operate on current are always perpendicular to currents. Dr.Genady V.Nikolaev called this field Scalar Magnetic Filed. It has rendered that for 200 years research of magnetism there exist except Vector Magnetic Filed B, also Scalar Magnetic Field S. So on some current element operate TWO FORCES - Lorenz and Nikolaev.
f = f(lorentz) + f(nikolaev) = Idr x B/c + Idr•S/c
The most interesting result which show manifestation of Sclar Magnetic Filed is next.
As you already know with help of three fingers of your righrt hand you can show if piece of wire with sliding contacts at his ends moving in plane perpendicular to vector magnetic filed B, B is in perpendicular direction to wire moving, than here is started such kind of current induction which interrelation with B filed bring braking (deceleration) movement of wire. That is well known Lentz law and the first term in above equation is his methematical formulation. If now with help of only one finger of your right or left hand you try to determine where will be induced current in wire with sliding contacs which finger will move in longitudinal direction of wire in Scalar Magnetic field S,
you will be in wonder because the induced current will not breakingmovement of wire but will help accelerating wire. It can be called AntiLenz effect. Everybody can test that antilentz effect with help of Siberian Colia Magnet. From this can be easy concluded that with the help of Scalar Magnetic Filed you can make perpetual motion S machine.
etc.
Dr.Stefan Marinov.
ps: People do not feed the troll(s) and don not listen anybody especially governement trolls if you want to make OU generator.. Listen yourself - your mind and check-up all.
That's all from me!! You are on your own !!
Enjoykin
T-1000
Quote from: Enjoykin on November 21, 2014, 08:21:29 AM
I was not intended to negate or throw away work in other fields. There are many ways to Rome (free energy) and to keep it not mixed up is best way not to confuse people.
Also the one who deviate from original 1st post is not me and the http://www.overunity.com/14691/the-marinov-generator is different from http://www.overunity.com/15088/new-generator-no-effect-lenzlaw-give-more-detail-in-pcture/
So who is trolling? :)
P.S> The personal insults won't work on me. Типичная руская психология - нашых никто небьют сдесь, так что безполезно нападать... ;)
