The new generator no effect counter B. EMF part 2 ( Selfrunning )
Started by syairchairun, November 09, 2014, 09:05:00 AM
thngr
Quote from: T-1000 on December 01, 2014, 01:49:56 PM
How about this? :)
http://www.overunityresearch.com/index.php?topic=2678.msg43489#msg43489
it is nice how ever coil return path is absent to allow coils' magnetic flux to dissipate.
magnetic shunt must be replaced after inducing magnetic field to the coils also magnets.
Just..Sayin..
I'd like to think these two videos were not just teasers.
I think we would all like to think that... I think we will see if the proof is in the pudding soon enough from those who busy building right now. JimBoot's results are very encouraging so far.
Here is a little build I am throwing together from some parts I had kicking around. Neos will mount on DC motor face behind rotor and L brackets will wrap around the rotor to the front to hold the coils. Going to forgo ferrous cores for the time being...
T-1000
Quote from: thngr on December 01, 2014, 05:29:36 PM
If to think in E. Leedskalnin terms my design is all OK. You have deflection force caused by magnetic flux increase in coil when iron bar approaches then you have magnetic flux decrease when iron bar shorts 2 magnetic poles of magnets (so you have attraction force from coil when iron bar is already under coil) and the in the last step when iron bar is moving away from coil you get opposite magnetic flux increase with deflection force. So the net Lenz force = 0 in iron bar movement around circle when you sum it up. Balance magnetic forces around circle and then have 0 physical reaction even in strongest magnetic coupling between magnets and shorted coil. :) Then unbalance deflection force from coil and make it stronger when iron bar goes away from coil and you get generator+motor in single coil...
thngr
To  "T-1000"
but how can you make this model (http://www.overunityresearch.com/index.php?topic=2678.msg43489#msg43489[/font]) compact and powerfull without closed magnetic flux lines?
T-1000
Quote from: thngr on December 01, 2014, 06:32:07 PM
To  "T-1000"
Having another layer with rotor from other coils side with opposite layout of magnets on second stator from the second disk side will make it closed in coils. Just for a start that is not so important for a sake of seeing Lenz force effect working for you and not against you.
