0 Members and 24 Guests are viewing this topic.
T-1000
Quote from: Mister Caribbean Roots on January 18, 2015, 05:52:33 PM
Hi T1000,
Got it...static ring magnet...rotating rotor with iron disks...static coil... ;)
I've just modify this setup to test a different generator setup and once i'm done i'll modify it like you wrote... 8)
Cheers
The http://www.overunityresearch.com/index.php?topic=2678.msg43271#msg43271 would help with this attempt.. ;)
Pirate88179
Quote from: Mister Caribbean Roots on January 18, 2015, 06:57:03 PM
I get this like a million times when i'm trying to post... :'(
This makes posting here sucha pain and costing me lots of time for just a few post... >:( ...lol
Connection Problems
Sorry, SMF was unable to connect to the database. This may be caused by the server being busy. Please try again later.
And even had this one,
I just posted about this in my topic about problems with the site.
I tried over 15 times with 3 different browsers over several hours...and still could not get on.
Bill
gotoluc
Quote from: Grumage on January 18, 2015, 12:48:36 PM
Dear All.
Suggestions/Comments welcome!!   :)
https://www.youtube.com/watch?v=5VTlQdTDLcg
Cheers Grum.
Good job Grum on boosting the output
Did the input change by linking all the coil cores compared to individual
Thanks for the update
Luc
Jimboot
Thanks mcr. Sounds similar to mine except I can only get mine down to 250ma when loaded.
shinz62
Dear All.
Cheers Grum.
Awesome! -- now it is time to optimize your configuration until you can get more out than you're putting in....
You want to try to maximize your use of the available magnetic field produced by your magnets.[/size]
[/size]
I would suggest that you need a magnetic loop from the back side of the coil (your top plates) back around to the under side of your set of magnets to form a full loop. Done right that should significantly increase the field strength that the iron rotor is capable of conducting across the gap through the coils without needing to resort to using stronger magnets.
