New generator no effect lenzlaw, give more detail in pcture.
Started by syairchairun, November 11, 2014, 08:46:59 AM
Dbowling
I think the most obvious question here is what is the generator or motor that was modified to create this design if there was one. If we had a model number we would all have some place to start. Or at least a manufacturer.
Dave
Magluvin
Dont believe Ive seen which poles are which on the mags. If 2 were N and 2 were S facing out, cogging would be nearly impossible to turn the thing. But, if all are say N or S out, when the iron portions go between the mags and coils, they just may be repelled a bit instead of attracted. The moving iron parts have a magnetic path to each other. Like poles repel.
So there can be a balance there. Say we had a 1 in by 1/2 in  by 1/2 in iron bar. Put a small mag(N) on one end, then another at the other end, both N in.  They will stick. But the bigger the mags are, the less stick there will be till the mags as you try larger ones will repel from the iron bar.  ;) ;) ;) So there can be magnetic switching this way without great cogging effects.
Mags
mscoffman
This units internal configuration bears remarkable similarities to the Wen Shum Ho
Self Running Magnetic Motor. Which was diagrammed completely on the web at one
time. It used a bowl of damping fluid to perpendicularlize the vibrating
magnetic motion of a mechanical eccentric into rotary motion.
Web Link;
http://peswiki.com/index.php/Directory:Wang_Shum_Ho_Generator
