OverUnity Does Not Exist!
Started by Nink, November 28, 2014, 09:23:20 AM
Tito L. Oracion
Quote from: Pirate88179 on December 04, 2014, 10:50:19 PM
No.  Where is the proof?
well, i thought that was obviously proven already. :D
Pirate88179
forest
You can dispute overunity here, but anyway soon scientists will find it....they are catching up right now..
https://www.youtube.com/watch?v=z2W5jaxKlgU&list=PLXBX9lLpBkP5gSw-TFnuvIto9nUS1REqv&index=8
rods
I'm not really too concerned about the many detractors here, many of them come off like minions of the big energy companies who stand to lose there positions if anybody does actually come up with a true alternative energy source.
For those who are asking for videos and pics of my lever powered machine. I will try to post some over the next month or so.Meantime here is a complete descerption.
The frame is built from 1"x 2" mild steel tubing and is 34" x 34" x 60", there is a cross tie top and bottom 10 " from one end. 4 angle iron uprights are welded to the cross ties, 2 are 12 " apart, 2 are 2" apart. On the 2 that are 2" apart I have 2 3/4" pillow block bearings, this is where the
fulcrum resides. The fulcrum is 3/4" round rod and runs through a hole in the lever 2" from the end.At the end of the lever is another piece of 3/4  round rod which serves as the upper axle for the connector rod. The connector rod has a 3/4x 2" sealed ball bearing attached to each end and is simply a piece of flatbar with a 2" pipe welded to each end which serves a the bearing holders. The other uprights have 2 2" pillow block bearings bolted on 8" lower than the 3/4" pillow blocks, this is where the crankshaft resides. The crank is built from 2" round rod 19" long, there is a 2" x 3/4" flatbar welded to one end of it with a 3/4" hole positioned 1.5" from dead center of the crank drilled through the 3/4" flatbar to contain the lower axle of the connector rod. Between the 2 large pillowblocks there is a 14"diameter by 1" thick flywheel mounted on the crankshaft. The total length of the lever is 52". One complete movement of the lever, top to bottom and return = one revolution on the crank with a ma of 25 to 1.
Nink
Quote from: forest on December 05, 2014, 01:40:18 AM
I am certainly open to the concept we live in an electric universe . I am also open to harvesting the energy from an EU. We harvest and use energy all around us every day (Wind Solar ....) . but I do not believe we can create energy from nothing.
I can build a graphene SWAG collector or an osmotic membrane bu I am just collecting a small amount of voltage from the potential difference in salt water versus fresh water and not actually creating energy.  At some point we will get better at developing new types of membranes to harvest this energy but for now it is not economically viable.
