Vaccinations; recent developments
Started by SeaMonkey, December 01, 2014, 02:12:40 PM
sarkeizen
Quote from: me"Absolutely false.  However if there's an instance where you feel further substantiation is necessary.  Please point out the specific instance and I'll be happy to provide it."
Quote from: moron on March 05, 2015, 07:58:02 PMReally? Prove it.
Well where is the specific point of contention?  Hmmm....you didn't provide one.  Well I'll give you a break and pretend you said:"Please show me where you have provided even one reference substantiating your point because I am so stupid I need to concentrate to breathe".
Quote from: meFirst study is the Cochrane review from 2012.  Which is a collection of studies of different types and sizes.  The conclusion of your PDF document is: "The design and reporting of safety outcomes in MMR vaccine studies, both pre- and post-marketing, are largely inadequate."
So this study was about comparing MMR to monovalent vaccines.  The discussion section begins thus:"We found only limited evidence of the safety of MMR compared to its single component vaccines from studies that had a low risk of bias. The few studies least likely to be affected by systematic error pointed to a likely association with fewer upper respiratory tract infections, increased febrile convulsions in the first two weeks
post vaccination and no increased incidence of aseptic meningitis (for Jeryl-Lynn strain-containing mumps vaccine). Low risk of bias evidence did not support a causal association with Crohn's disease, ulcerative colitis or autism."
Huh...waddya know?  I did reference a study.  I provided a whole paragraph from a study.  One that you didn't read because you don't care what the science says. :)
Quote from: me"I have absolutely no problem with providing further substantiation"
Quote from: moronApparently you do.
The full quote ends "you just need to point out the specific point of contention".  Have you pointed out a specific point that wasn't responded to?  Not really.  I've said it several times.  Say words like: "You said X.  Can you provide a reference for that?" and I'll provide one.
But of course, you have absolutely no interest in challenging your poor brain with a belief contrary to your own.  Otherwise you would have asked. :)
Quote from: moronAnd where are your posted studies? Hmmm?
Well there is that one right up there....the point is if you're whining what I'm posting is merely my opinion (which apparently it isn't so your whining is incorrect) then we ask: "What have you been posting?"  Seems like you're just posting empty words.
But again...you're not interested in knowing that.  :)
joel321
QuoteIf HVAC repairmen used JB Weld, they would not have to charge as much for their repairs.  Instead, they sell new parts that folks do not even need.  I have repaired my heat pump with JB Weld and it is still working after 3 years now.  Total cost?  $3.00.  Estimate from the repairman?  $450.00.
You kind of have the right mentality. I personally have been fixing stuff since I was 5 years old. I'm a jack of all trades master of none. I'll admit that but I have been fixing stuff since 5 years old...
As of right now, I know the following.
-In any power supply that gets plugged in the wall, will stop working due to only cheap capacitors. A new one from the company will set you back $20 USD while the only thing that went bad is a $.10 cent USD capacitor.
-Most LCD TV's fail in the power supply high side in the board. Could be a diode, could be a cap, could be a relay, 90% of the problem is in the power supply. Same applies to computer monitors.
-Most of the USB wifi adapters that suffer from signal problems, or what not, is due to the chip getting over heated. The same applies to game consoles. You know the ps4/xbox one light of death deal. Same thing. The chip gets over heated due to the manufacturer using cheap products to save money...but ultimately, when the chip gets overheated, the solder gets compromised and develops bad connections. This is 100% facts.
-your dishwashers' motor, or an HVAC, motor will fail due to the bearings. They don't use ball bearing, they use copper sleeves along with carbon fiber shims as bearings...when those wear out, and they will, your motor shaft will "weld"...= rubbing metal to metal with no lubrication.
Etc etc etc...all of this is well understood and can be prevented. They just have to use products that will last for 30 years. But, I believe that they do it on purpose. Just imagine if they make a products that can last for 30 years? How can they sell more products and make a profit?
So you have a point that you can save a lot of money by using JB weld, and not only that, you can actually use a welder to weld it, or a tap and die with a screw = instead of using jb weld, use a metal screw to keep it all together.
The problem is that I believe that they are cutting CORNERS with medicine too to save money. When they do that, they are not gabling with machines anymore, they are gambling our health. "sir the vaccine is not ready to shit out", "i don't care I have a quota to meet, ship it!!!", "let them figure out later what went wrong".
That is the mentality of MANDATORY vaccinations. It cannot be allowed to do as they wish turning us into human lab rats.
sarkeizen
Why begin your post with some long meandering pointless story?
Quote from: joel321 on March 05, 2015, 11:21:43 PM
...and the evidence for this is what exactly.  See instead of just vomiting up things about PSU's you could have been looking for actual evidence to support your point about medicine.  Do people normally listen to you?  Seems like a waste of their time.
Just sayin'
joel321
Quote...and the evidence for this is what exactly.  See instead of just vomiting up things about PSU's you could have been looking for actual evidence to support your point about medicine.  Do people normally listen to you?  Seems like a waste of their time.
Yawn! hey there pet. Go sit down I'll change your diaper later 'cus I'm busy right now.
sarkeizen
Quote from: joel321 on March 05, 2015, 11:58:30 PM
You can namecall all you want but it doesn't change that you spent three or four paragraphs talking about nothing medically relevant.  Finally you make some kind of point and....nothing.:)
Next time you could just not post.  It would be almost identical.  :)
