Vaccinations; recent developments
Started by SeaMonkey, December 01, 2014, 02:12:40 PM
SeaMonkey
Quote from: Sssssss-ar-Keeeee-Zzzzzzzzzzun
However it's high time that you were asleep...
Aye, that is the wish of the Matrix and the principal
goal of the Media - putting the masses to sleep.
Whether it be the 'sleep' of preoccupation or the
'sleep' of death.
Your Candid Slips are right on cue.  Well programmed
Zombie that you are.  Many thanks.
sarkeizen
Quote from: SeaMonkey on April 02, 2015, 10:39:03 PM
Your Candid Slips are right on cue.  Well programmed Zombie that you are.  Many thanks.
So you postulate that my mentioning of going to sleep can only, in your mind (such as it is) be interpreted as something contributing to your conspiracy delusions.  To you, it's impossible that I was using a metaphor to represent your naivete?  As illustrated by the way you describe a world of potboiler dramas and monsters under the bed. (although it wouldn't surprise me that much of what you post is fiction - even to yourself).
And all, unsurprisingly after having your ass handed to you several times over when discussing math and your quaint notion that it's the same as what you use a slide rule for. Based on your past behavior I'd guess that "many thanks" probably implies that you're kind of ticked off. Awesome!
Anytime you feel like being less transparent just let me know. :)
joel321
You surely entertain man in a certain way. lol
QuoteSome epoxies are mixed by weight, and some others by volume.  You can actually make an epoxy more flexible by adding a bit more hardener, and vise versa.  The best epoxies need to be fired in a controlled oven environment.
If you think about the wold being epoxied (if that even a word), or duct taped, whe can put in a graph the items that have epoxie and those that not. Hmmmm lets think about that for a minute...
-Gorrilla glass. Most every smart phones's touch screen is held by either double sided tape or epoxy. Aside from that, a smart phone does not have epoxie in other areas.
-Cordless drills (which I'm sort of an expert on, sort of). The only epoxy that I could see is in the commutator fan for the windings. The fan is plastic held there by an epoxy to the commutator. All of the rest of the parts are metal.
-Speakers. All speakers I have encountered have epoxy glue. The speaker coil is held with epoxy to the speaker cone. The magnets are held to the metal with epoxy. You can even see this during speaker making in china.
-Cars/Boats. The engine has no epoxy what soever nor the lever connections. The only-thing that I have noticed that have epoxy is the body panels...IOW, the outer panels in the metal frame. And lets not forget when there is an accident, it gets patched by epoxy, sanded, and panted. Or just replace the whole damaged panel.
-Computers. I have built a few computers and they don't have epoxy!
-LCD TV. I have repaired a few LCD TV's and have never encountered any JB weld epoxy.
-Engine radiator. I have repaired an engine radiator water leak with JB weld, and it will leak. The BEST repair was/is to weld. If the radiator is plastic, weld plastic to it. If metal, weal metal POINT BLANK! No of and whats about it.
You JB weld "fix" is aching to repair a broken glass with JB weld....lol. Thanks for the laughs.
QuoteI do not know what you have against these chemical bonding agents.  Did you know that our composite winged jet fighters use epoxy?  Did you know that the first private launch into space used epoxies in its construction? (Space Ship 1)  Did you know that the ceramic tiles on the space shuttle were attached using an epoxy?  The list goes on and on Joel.
So, all of these modern flying machines can use this stuff but you refuse to repair your car with it?  This makes no sense at all.  I mean, it is not like you are going 17,500 mph (orbital velocity) in your car...right?  So, epoxies are good enough for that but you do not trust them on your car?
You need a new battery?  How do you know?  What is wrong with it?  If the electrolyte is leaking out of the case, yes, you can repair that with JB Weld.
No you won't...funny enough I had a minor automobile crash and it punctured my battery. JB weld did not stop the leak. The acid just peel it off like nothing.  I tried this when I was about 20 yrs old. I still got a new one from the company due to out of the factory insurance. Which is mostly a year due to items that get past the assembly line that are defective. = not all items that come out of the assembly line are 100% working as they should (assembly errors).
QuoteIf your filler caps are broken or missing, yes, JB Weld can handle that too.  If your lead plates are sulfated, you can can repair that by pulsing high voltage spikes and using a chemical cleaner and adding new electrolyte.  Your battery will be good for another 5 years.
JB weld on the caps just means your ignorance! Why? Because the acid inside a led battery fluctuates. Even though the caps may look 100% sealed to you, that is not true cause the acid level inside is not static. The same principal is in engine gas tank caps. You fail yet again sir lol.
Regarding the rest, i'm sure I could open up a battery and clean out the cells by hand from those harmful battery microcospic elements, or just replace the cells and fill the battery up.
QuoteBut no, you want to toss that battery away and purchase a new one.  Rather than fix what you have, you replace.  That is fine if you can afford to do that...I can't.  (I actually do not know anyone personally that can either)  So, dishwasher fan blade comes off?  Just throw it away and buy a new dishwasher.  It sounds like you are keeping the landfill folks in business all by yourself.  I prefer to repair the stuff that I have and keep it in good working order.
lol...I'm not saying I want to throw everything away...I'm saying that JB weld fix is the lazy way! Why instead of JB welding, did NOT upgrade the part? JB weld is JUST LAZY! In todays day and age, JB weld is crap and lazy...it is not a permanent fix.
If your mentality transfers to your support of sarkcheiken, then you two seem like an odd ball. You are more of a sort of recycling type of person while sarkcheiken is more of the type that want to take your money. Maybe you are in the wrong side of the debating lol.
sarkeizen
Quote from: joel321 on April 03, 2015, 03:48:39 AM
Do you really think there are "sides" here?
I mean really?  Do you believe in SeaMonkey's delusional ideas about shadow governments with people who never get sick because of super secret MEGA VACCINES? Is that YOUR SIDE Joel?  Because it's pretty freaking hilarious if it is.
SeaMonkey
Quote from: Ssssss-ar-Keeeeee-Zzzzzzzan
Sarkey, you have much to learn and discover
about our World and its structure.  The Power
Pyramid is Demented and Ugly.
Apart from their Mental Illnesses, no, they do
not suffer the debilitating disease inflicted upon
the masses.  Providing their support of the MATRIX
is constant.  Wavering or regrets lead to 'termination'
by airplane or some means of 'suicide.'
Your pretense at not being aware of these things is
not convincing.  Your game is deception?  The levels
of fear and desperation which comes through in your
responses is immense.
