Vaccinations; recent developments
Started by SeaMonkey, December 01, 2014, 02:12:40 PM
SeaMonkey
Quote from: Sssss-ar-Keeeeee-Zzzzzzzun
... Well then you're just offering another bite of shit sandwich. :)
Sarkey!!
Your desperation keeps descending to ever lower levels.
Don't take your ineffective shillings so hard man.  Losing
is often painful to be certain, but losing control as you've
done is painful to watch.  The Charlatan reveals his true face.
sarkeizen
Quote from: SeaMonkey link=topic=15147.msg44508X"3#msg445083 date=1428295726
but losing control as you've done
Uh how exactly is a Spinal Tap reference "losing control"?
The fact remains that none of you are capable of saying: "Oh this over here strongly supports X" which means regardless of what you post you're just serving up the same old shit...occasionally changing the bread.
sarkeizen
One thing interesting about the last few things that Magluvin shat into your wide open mouths is that they rely on an almost magical concept of medicine.  Which is ironic considering how much time he and the rest of you shit-eaters want to criticize medical science.
See normally if you're going to say "Diagnostic X implies condition Y" that's because there exists a body of established work demonstrating X correlated with Y (i.e. double-blind placebo controlled studies)  and the mechanism behind X / Y being related (usually some kind of longer theoretical work) as well as evidence establishing this mechanism ("petri-dish" science).
But when someone proposes an effect for which there exists NO DIAGNOSTIC WITH AN EXTANT BODY OF SUPPORTING WORK CORRELATING IT TO SOME DIAGNOSIS.  Not only that but you wonder how they failed math so badly.  See every outcome with the same weight of evidence ABSOLUTELY MUST be considered equally probable. Since the diagnosis A caused B has no diagnostic or mechanism which supports it - it must be equal in probability to every other A caused B which also has no evidence supporting it.  Making a differential pretty much impossible.  Which probably means they just walked in with some preconceived notion.
The only reason this is believable to people like yourselves is that you effectively believe that medicine is magic.  That is to say having no plausible way of getting from some set of symptoms T to some diagnosis U has no effect on the credibility of said diagnosis.
sarkeizen
Quote from: MileHigh on April 06, 2015, 10:35:05 AM
Run for the hills!
Is the pizza really gay?  I've always thought of pizza as kind of asexual.
