Vaccinations; recent developments
Started by SeaMonkey, December 01, 2014, 02:12:40 PM
joel321
QuoteExactly why I only use deodorant....once I learned this difference in college in the 70's.  Sorry, no Google back then.  JB Weld is great, you might learn how to use it one day.
Well I don't use a deodorant nor antiperspirant cause I wash my armpits. Since the 70's you have not washed your armpits properly bro? Lol
I know about JB weld very clearly, and I tell you, JB welding a fan motors blade will eventually fail....it is wayyyyyyyyyyyy better to drill a hole and use a screw and nut to keep them together, other than that, use a welder to weld the two! But JB weld is the bottom feeder.
How old are you bill? Much respect for the elder.
Pirate88179
Quote from: joel321 on January 10, 2015, 02:02:13 AM
Well...that fan was repaired without removing the motor...which was the point.  This woman had called a "certified" repairman, and he told her that he had to drill out the rivets holding the motor to the frame, and then replace the motor.  His estimate?  $250.00.  I repaired it for her for less than $1.  I did not have to remove the motor.  This was over 4 years ago and, last time I saw her, she thanked me again and said everything was working just fine.
So, I am not sure what your point is?  There was a problem, I fixed it...it is still fixed.  JB Weld will eventually fail?  Well, the spot weld from the factory eventually failed after only 6 months.  Your point is?
Yes, I shower daily but, if you do not use a deodorant, then I am glad you are wherever you are and not here.
joel321
QuoteWell...that fan was repaired without removing the motor...which was the point.  This woman had called a "certified" repairman, and he told her that he had to drill out the rivets holding the motor to the frame, and then replace the motor.  His estimate?  $250.00.  I repaired it for her for less than $1.  I did not have to remove the motor.  This was over 4 years ago and, last time I saw her, she thanked me again and said everything was working just fine.
Yes but I 100% here can tell you that JB weld is not as strong as induction welding, plasma welding, or bolts holding it together.
I can appreciate you fixing her dishwasher with JB wled, but that does not mean you understand how the whole dishwasher works. In fact, the engineers whom designed it know this and her dishwasher crapping is just a matter of assembly line error, nothing else nothing more. The mere fact that your "fixed" the fan to the motor is no big deal. You should not be proud of since that fan was made to cool the motor windings! IOW, the motor needs air circulation over it to cool it down or else it will over heat and the windings will short out! But you don't think about WHY dishwashers fail even if their FAN BLADES are in tact in the motor shaft do you? NO! You only based fixing dishwasher based on your JB weld Fixing! Only.
QuoteSo, I am not sure what your point is?  There was a problem, I fixed it...it is still fixed.  JB Weld will eventually fail?  Well, the spot weld from the factory eventually failed after only 6 months.  Your point is?
My point is that you understand why the fan is there in the first place right? And if the fan is not there, then the motor dies? It is like the heart of a human! Jb welding for four years is not the same as living for 100 years.
Why are you so proud of fixing this motor blade with JB weld? It is not as strong as actual metal to metal welding and this has been shown by those dorks of "myth busters"...case closed!
QuoteYes, I shower daily but, if you do not use a deodorant, then I am glad you are wherever you are and not here.
lol, Why do you use a deodorant if you wash the bacteria away from the armpits daily?
Pirate88179
Quote from: joel321 on January 10, 2015, 02:34:11 AM
Myth busters are idiots, and if you do not know this than you are ignorant.
So I do not smell like you.
joel321
QuoteMyth busters are idiots, and if you do not know this than you are ignorant.
Well you just ignored everything I said before I mentioned the "myth busters"...I have nothing to say to that that I find them stupid!
Still, I don't see the MAIN point you are trying to make!
Tell me why armpits stink and need deodorant? Yar yara yaray!
QuoteSo I do not smell like you.
LOL, all armpit bacteria smells the same. You telling me that you use a "deodorant" to cover the smell only implies you are covering the gases the bacteria emit. I tell you that I don't use a deodorant because I kill armpit bacteria and you tell me that you are glad that I kill armpit bacteria while you just use a deodorant to cover yours, priceless. I seriously don't find any brain power in your brain bro.
Use deodorant to cover the bacteria smell while I don't use any because I don't allow the bacteria to live there! OK! Call me stupid!  ::)
