Why doesn't negative voltage work?
Started by d3x0r, December 04, 2014, 11:46:09 PM
d3x0r
That's not to say it doesn't 'work' it uhh.. does strange things with the biasing...
like why is the collector -27V? shouldn't be more than -12?
went back and added more notes of known values; the transistor doesn't seem to matter... larger volt/amp seems to be better... though... right now... I'm getting decent voltage output with < 300mA input..... so maybe I can even go small signal...
87uH coil resonates at harmonics of 16Mhz (4mhz, 1mhz, 528Khz) I can use any of these to get voltage output... lower frequency is higher power transfer (higher current similar voltage)
This is all really Ruslan stuff simplifed to just the kacher and coil as last demonstrated...   just got to a point that I seemed to have decent output; but the 1Mhz frequency is messing up my meter still... even through the diodes and capacitors...
d3x0r
circuit implemented
http://youtu.be/3af2e6JZjVc
I have a similar sim from falstad probably...
first image: (this uses signal generator instead of kacher... )
second image: not kacher either... but mazilli; extra complication for series resistances... so in some ways my 'napkin sketch' is better.
was also testing my new digitizing input thing... learning new hand eye coordination; and I dunno... maybe cause it's my handwriting it's more clear to me...
