Pulse Pendulum Projects
Started by PhiChaser, December 07, 2014, 11:55:10 PM
Kator01
TK,
very interesting remarks...but you are falling prey to your own assumptions.
Where did I state anything about OU ? ...preconceived notion.
But anyway your remarks showed me that you did not perceive  the figures he gave: Input is about 10 Milliwatt.
Yeah, one has to pay attention before jumping to conclusions.
Can all these lit LED`s run by 10 mW ?
Kator01
Quote from: Kator01 on December 09, 2014, 07:46:58 PM
TK,
Kator01
The video Description in the linked video reads, "Over-unity energy generator using extreme magnetism with neodymium magnets."
The narrator uses the words "overunity" several times in the video and talks about increasing the overunity ratio. This constitutes a claim, in the English I speak, of overunity performance. You may not be making the claim but the originator of the video certainly is.
The LEDs are not "run" by 10 mW at all, they are flashing very briefly and the peak power during the impulse that makes them flash can be very much more than 10 mW. No measurements of output or input are given that I could find, just some random uninterpretable squiggles on a scope screen. Power is not energy and peak power, especially, is not energy. We actually have no idea what the peak power is that is flashing the LEDs.
Contrast with this:
http://www.youtube.com/watch?v=jGmbN1CzmsQ
The six bright green LEDs are indeed running _continuously_ on filtered DC at a continuous power of.... wait for it....  around 1.3 mW, by actual measurements using an inline ammeter and a parallel voltmeter. I don't show the current reading in that particular video but it is about 100 microAmps of DC current.
How about this one I just did today, showing a 100-to-1 voltage rise from input to output, with current in the output strong enough to heat 3 neons to near-failure?
http://www.youtube.com/watch?v=xiYOaguki6c
Peak power is not energy. Peak power amplification of even hundreds of times over average power is not necessarily overunity.  Voltage is not energy, current is not energy. Only more energy out, than in, over a reasonable time, can be truly overunity, and nobody has demonstrated that with reliability and credibility yet.
PhiChaser
@TK
The diode was a 1N978B which is indeed a 51v zener. I found a PDF for Motorola diodes here https://www.westfloridacomponents.com/mm5/graphics/F01/1N5231DRL.pdf
I hooked up the power supply just to see if those neons (HV rectifier and HV regulator each have one) came on and no, they did not. But I did see a little orange glow on the calibrator regulator board from what looked like a Christmas light (neon?), not sure this is a good thing? Looks like the inside of it is getting black...
I am only getting 10.4v instead of 20v at the power supply test point (I should have checked this earlier...), 80v test point was within stated tolerance.
Time to relocate my 'mess' so it doesn't take up the whole dining room table heh heh.
Thanks again! I will try to do as you suggest, I'm pretty green at this kind of testing/repair.
PC
picowatt
Quote from: PhiChaser on December 10, 2014, 01:50:31 AM
@TK
PC
PhiChaser,
The 422 manual that TK provided a PDF link for does not include the complete power supply schematic.  I assume that your scope's supply is the "AC only" version (there was an AC/DC supply for battery operation available as well, possibly only for the later FET versus nuvistor models).
Anyway, here is a link to a site where you can download the "AC only" power supply schematic:
http://elektrotanya.com/tektronix_422_ac_only_power_supply_1966_sm.pdf/download.html
Just scroll down the page to the "Get Manual"...
Also, what kind of meter do you have for measuring voltages?  Hopefully it is something with a relatively high input impedance...
PW
I'm not a huge fan of elektrotanya although they do have some manuals you can't get elsewhere. They have adware and try to get you to download a reader etc.
But the 40 page AC power supply manual is also available from the TekWIKI site, which is a great resource for all the older Tektronix scopes:
http://w140.com/tek_422_ac_powersupply.pdf
Other manuals too, for later serialnumbers, etc:
http://w140.com/tekwiki/wiki/422
