POST YOUR TESLA BASED THEORIES ON ENERGY GENERATION
Started by gemstone hell, December 09, 2014, 02:44:20 AM
delboy
Hi all,
As topic says "TESLA BASED THEORIES ON ENERGY GENERATION" I will give some comments..
Tesla did produce large coils for generating HV/HF (high voltage - high frequencies). Ask your self why did he do that? Obviously not to throw sparks all around to impress somebody because that is what is left today and what everbody do, sad but SO TRUE!
Compare his design and have in mind that it was over 100 years ago (no electronics to drive FETs MOSFETs etc.)
He started in NewYork and his laboratory became to small for what he had in mind to do. Read his patent 645576 where he explains in details how his one working coil was designed. Some of characteristics :
- diameter of coil 240 cm
- source power 50 kV
- primary cap. Cp=0,04 uF
- primary ind. Lp=10uH
That will give resonant freq. about 250 kHz[/size]
-Primary turns Np=1 (stout stranded cable)
-Secondary turns Ns=50 (AWG. No.8  ~ 3,2mm diameter of wire)
-mechanical-break 5000 times/second
Output voltage from 2 to 4 MegaVolts !
Compare that design with design of today. You did not produce TRUE TESLA COIL, you are just making some copies to impress someone.
And what about receiver? When we are going to see some receivers like Tesla made in patent 787412. It doesn't have to be "through ground", it can be one-wire connection between Transmitter and Receiver.
Guys we are 120 years late, we are not moving forward. We are stucked somewhere in 1890s where only three-phase system of power distribution is working.
No HV / HF designs for industrial purpose, no education in schools, yes that is true, not even 1% of what Tesla designed after 1890 is found in school books ?!
Do I have to mention that Tesla moved in Colorado Springs and designed coil 15 meters in diameter with only 35 turns on secondary ?!
Try to read something about Tesla but read it chronologically because only that way you will understand Tesla. Read his patents, notes and articles... and maybe you will find "how deep rabbit hole is".   ;)
padova
But to this days, except maybe in one case, no one has ever successfully replicated his magnifying transmitter.
All work was stolen a century ago. :) sad but true.
delboy
Quote from: padova on April 10, 2016, 04:44:53 AM
I do not agree! After 100 years nobody to replicate something that Tesla very well described and patented and published ! Do you have 100 000 $ to build something like that for GLOBAL purpose ??? If NO than try to build something for HOME USE but build it in way Tesla described, patented and published. Problem is that people do not know what and how to do with it, and they think they are the SMARTEST and build TC for spark light show to become lightning masters  :D  That is situation today. We have better copper wire, better switches, better insulation than Tesla had and NOTHING. It is like you give airplane to some tribe in jungle and what would they do with it, they would just have sitting around and look at it, maybe afraid, maybe surprised who knows. But point is that they would not know how to use it, what is purpose etc.
Tesla made AC POWER system distribution with PURPOSE and everything is working okay, but one thing is wrong, you have to keep stove burn coal if you want POWER. You are wasting almost 60% of what you invest (COAL) than you GET (water steam) to run turbine and generators because steam turbines are only 35% effective, we didn't even try to change this with Tesla turbines that are 95% effective. Next step is to eliminate coal stoves and water steam turbines (he tried but who is Tesla to decide that big STEP)
No resonant accumulating system that will give power only if receiver is connected. That would be third industry revolution and Tesla did it. It is up to you to understand it.
We were not prepared for that and those up that rules our lives (GOVERNMENT) acts strange when you give them POWER over something. Imagine how they act when you try to take their power away ;)
Century passed you say, but look around, everything you see there is Tesla and we did everything to forget about him and his teachings. You will not find in school books his spiral coils, impedance phenomena , how to build TC because there is no school for HV / HF high voltage high freq. You have school for high voltage but 50 or 60 Hz and you have schools for high freq. radio amateurs etc. but nothing combined. In this way Tesla reminds me on Bruce Lee where he states that you have to combine all arts to become BEST OF ALL.
What would you do if you would have your own true TC, it is same as if you ask yourself what would I do if I have bomb. Would you keep it for your self or would you sold it? (If you know how to drive plain than you will use it correctly) ;) Because today everything is money, at least 99% of people think it is.
Remember how Tesla reacted when someone asked him would that ship that is operated wireless be used for transport of some bombs in wars and ask your self what you approve and what not! Would you split Earth in two pieces  with some machine or would you say "Hay if you give me 1 billion dollars than I will not do it" !
forest
It's not just about Tesla. He patented some strange devices to show he learned the secret knowledge hidden from very old times. Our current world knew about it for sure from the Faraday times. The so called "crooks" like Daniel McFarland Cook were proof of that.
Overmind
Tesla's tower was similar in concept to how pyramids worked as power plants (yes, they were power plants, not graves).
If you want to generate power in a similar manner, perhaps you should check the similarities more closely.
I currently try to take the 'capture power from any possible sources approach' since there are plenty things that spam us with power currently...we just need to convert it into usable power.
