Generator by Gerard Morin
Started by d3x0r, December 15, 2014, 04:34:16 AM
scratchrobot
Quote from: citfta on October 15, 2015, 11:24:09 AM
Sorry but if you think volts and amps are the same you really need to spend some time learning a little about electronics.  Voltage readings or current readings by themselves mean nothing.  You have to combine the two to get a power value and THAT is the only value that means anything when trying to measure efficiency of a circuit.
As far as that video it means nothing.  In fact it is a joke.  Why is he using a meter that has an almost dead battery?  Anyone that has a digital meter knows the readings get flaky when the battery gets low.  And why does he need another transformer to step the voltage down to 12 volts and rectify it to charge the battery when he already has a battery charger connected to the battery?  And what are all the caps for?
Gerard showed a video almost identical to that one where he took the power from a battery and ran it to an inverter and then to motor controller and then powered the motor to drive a generator which he then fed back to a battery charger and claimed he was keeping the battery charged.  He said he was going to come back in the morning and show us the battery was still charged and the system still running.  The video ended and we never saw what he found when he went back.
Respectfully,
Carroll
I don't think volts and amps are the same, Gerard Morin does in the video i posted, he is mixing volts with amps and thinks his multimeter is a geiger counter, how in the world can you belief this guy  :o
citfta
Quote from: scratchrobot on October 15, 2015, 01:57:24 PM
Sorry about that.  I didn't realize you were quoting from the video.  I should have read more carefully.  And I agree I don't see how anyone can believe that guy.  I expect one day we will read where he or someone else trying to do his tricks will have been electrocuted.  I don't think he is funny at all.  There are too many gullible people in the world today that believe anything they see.  Just like Ufopolitics he can talk a wild game and will lead a lot of people to spend a lot of money they probably can't afford to try and get free energy.  There are many people on the Erroneous Forum that have spent hundreds of dollars buying motors to try and make what Ufo promised them.  Now they are all gone with no OU motors and Dufo is trying to make a magnet motor.  I hate to see people so foolish with their hard earned money.
Again I apologize for misunderstanding your post.
Respectfully,
Carroll
memoryman
citfta, I too have 50+ years in electronics. I also work in cnc maintenance/upgrade/repair. We actually may know each other.
citfta
Hi Memoryman,
Anything is possible I guess.  I worked for a Defense contractor in Louisville, Ky.  I retired 8 years ago.  Where did you work if you don't mind sharing that publicly?  Or send me a PM if you would rather not make that info public.  What brand of machines did you work on?  I worked on Cincinnatti Milacron machines and Kearney and Trecker machines and many other smaller brands.  These included lathes and mills and even a couple of industrial lasers.
Carroll
memoryman
Hi Carroll.
No, I don't make a secret of my life.
I worked for GE in the middle '70s as a field service engineer, Mark Century 100, 7500, 550 and 1050 controls, along with Umac controls. Went independent in '79 and serviced almost anything (Cinci Milicron Big Blue, some K&T, Fanuc, and whatever else came up. Designed my first product in 1988 (GE1050 memory board) and did many Fanuc control memory upgrades, with Mitsubishi and Yasnac next. you may have heard of my company Tulip Electronics.
