Generator by Gerard Morin
Started by d3x0r, December 15, 2014, 04:34:16 AM
Jeg
Thank you Tinsel and scratchrobot.
I just wonder what happens if inconceivably small time interval is so small, magnitudes smaller than the actual RC discharging constant of the circuit. Capacitor or coil or battery, in such a small time interval doesn't have time to give any current at the output. Only pure voltage pulses or radiant if you like will be released. Isn't it a fact that radiant induces current by its interaction with copper? If not I am sorry for mentioning this. But if it is like that, how can someone predict input and output consumption numbers with the well known equations?
scratchrobot
Quote from: Jeg on October 18, 2015, 07:38:39 AM
Isn't this what Bedini is doing? I think it is very difficult to predict the numbers but many experiments have been done but none resulted in overunity.
Jeg
Quote from: scratchrobot on October 18, 2015, 09:08:44 AM
The question for me is how many experimenters have made a solid state switch that hard closes and opens few million times per second and able to withstand serius amounts of voltage without the ionizing effects of spark gaps?
Quote from: Jeg on October 18, 2015, 09:49:43 AM
Lots of them. All builders of solid-state Tesla coils, for example. Big SSTCs using fullbridge IGBT primary drivers, for instance.
And even small ones using just a single mosfet with a PLL driver configuration:
http://www.youtube.com/watch?v=XeQ5WnziKBA
What is this "radiant" in your definition?
In all cases I have ever seen, "radiant" refers to what is actually radio-frequency, more or less high voltage, broadband noise. Which creates an oscillating EM-field, which has the various effects we all know about. Pure voltage pulses? Voltage is charge pressure, relative to some reference, which happens because someone or something is stuffing charge into a reservoir (or draining it away).  When charge moves... as it must in order to produce a voltage difference... that is current.
