Lenz free generator
Started by life is illusion, December 21, 2014, 03:20:03 PM
0 Members and 31 Guests are viewing this topic.
tinman
Quote from: webby1 on October 05, 2016, 10:13:27 AM
If the pebble is large enough the water will not cover the pebble,, but the propagation of the disturbance still happens.
If the water is deep enough it will encase the pebble before the pebble stops moving.
There are so many variations that the pebble and pond only describe a means of the disturbance being communicated throughout the water.
Do you think that the pebble and water describe all of the interactions that are possible??
No,but you were talking only of the magnetic field,while the electric field associated with the magnetic field seems to be always forgotten.
What is the field that is inducing the single turn secondary in the video below,if all magnetic flux is suppose to remain within the core of a toroid transformer?
https://www.youtube.com/watch?v=yYpz9ak34e0
web000x
Quote from: web000x on October 05, 2016, 07:39:05 AM
I have heard of this and halfway attempted to replicate it at one point.  I am not sure I saw anything interesting as I was not doing it exactly like paul does with the controlled collapse of the inductor thru his switching process.  But I would think the same thing should happen in pulsed coils where the inductive reactive energy is collected in a cap or used up somehow.  So theoretically if all of the magnetism has been removed from the coil, the coil should show a reduced impedance to the flow of current and all pulsing/capturing rigs should exhibit this reduced impedance phenomena.  I don't think they do... What are your thoughts on where the disconnect is?  Since Paul talks about being able to run full current thru 300 mH coils at 400Hz....
Dave
Okay, so on second thought after running a few experiments.  There is definitely a significantly reduced impedance when maintaining magnetizing force in one direction.  However, I am still unsure of how Paul got got his full current thru those coils....
i_ron
Quote from: tinman on October 05, 2016, 10:33:47 AM
The A field
https://en.wikipedia.org/wiki/Toroidal_inductors_and_transformers
Ron
EMJunkie
@AC - Some time back you made an interesting comment:
Quote from: allcanadian on September 19, 2016, 09:39:26 PM
IancaIV
It is well known the electrostatic force is very large. I believe the numbers say if we had two 1 m^2 plates spaced 1 meter apart and moved 1 ampere of current of opposite charges to each plate the force of attraction generated would be 1 million tons. This cannot be done for obvious reasons however that does not change the fact the forces are extremely large.
In another example if we took a cube of aluminum as big as a sugar cube and separated all the charges in it 1 meter apart the force of attraction would be 32 million million million pounds. Equivalent to the force applied by the weight of a cube of steel 76 miles high, 76 miles wide and 76 miles long.
I know all these things from memory because my primary field of expertise is electrostatics outside the context of my occupation as an Engineer. Electromagnetic phenomena has been well explored however electrostatics is still considered the black arts in many circles. We have much to learn in this area.
AC
Sadly, it took me sometime to find the data I was looking for. But I found it.
I have ponded over your comment for some time. My interest in this field promped me to ask, What makes you believe "Electromagnetic phenomena has been well explored"? Personally I believe there are massive Holes, even some inconsistencies.
Some work that is also questioning similar area's is: Incompetent Science - by Carl van der Togt
His work in the famous Aether Experiment of Michelson–Morley is alone ground breaking.
   Chris Sykes
       hyiq.org
                              MHD/MED- channel/tube f.e. as "toroidal air core"
                                        incarnation/realization of the
        der Schein(the shining/imaginaere Kreis/ imaginary-virtual circle) der Heiligen(Saints)
