Lenz free generator
Started by life is illusion, December 21, 2014, 03:20:03 PM
Magluvin
Quote from: Erfinder on November 14, 2016, 02:37:35 AM
Attached is the "concept" which has inspired thousands, indirectly.  The majority did not allow themselves the opprotunity to examine the source.  Preferring the spoon to mouth, only those parts, or specifically, that part which can be sourced back to "the concept" was prepared for them, and fed to them.  If you choose to examine the document and those which relate to it, understand that if you take it at face value expect failure.  Do not judge a book, this book, by its cover.  See it for what it is, and be accelerated into the unknown.
How this relates to the subject... I expect you will fill me in when you get there.....if you get here.
Also, this is a version of the circuit in a simpler depiction. It only has 1 cap and 1 large inductance, and this one is DC input with switching dependent on the gas engine rpm.
The idea behind it from what I understand is when the points switch is closed, the large inductance gets charged up, then when the switch opens, the large inductor charges the cap. Then when the switch closes again, the cap gets discharged into the spark coil primary, secondary delivers spark and the process starts all over. In a typical points system of today and apparently back then, the closure of the points puts the battery source across the spark primary directly, consuming lots of current from the battery during the on time, and when the points open, the field collapses and sec gets induced to spark. So from what I get it that this circuit is its more efficient than typical points systems as the large inductor does not consume as much in order to charge the cap.
There may be more to it than that if it can be used to produce ou.
Mags
tinman
Quote from: i_ron on November 13, 2016, 11:04:30 AM
Oh give us a break, the secret government already has this technology (UFO's, weather control) and is already misusing it, why put the blame on us? It is just more, "blame the victim"
The point I was making is that we are being called stupid, yet in 82 pages you two have not posted ANY education material.
Ron
Hate to say it(ok,i dont hate to say it :D),but i told you so. ;)
Like i stated 80 pages back--same old- same old.
And in another 82 pages,there will still be a void of educational material--but lots of bathroom heaters.
Brad
forest
Somehow the output is high current.Somehow the input is low current.Somehow the large condenser is depicted but we know that the flyback spike during disconnect of high inductance coil is HV low current, yet it will charge that cap or the picture is misleading and the cap is HV caps in paralell... ;D
forest
So can you charge say 20 HV caps from single spark ? So can you discharge them to get HF. So can you get the movement of energy in the MW oscillations. So can you collect 10% or use the way to collect more if you wish ?
