Lenz free generator
0 Members and 20 Guests are viewing this topic.
VMP100
Hey there Dieter!
I think we should just try to build it and test it instead of trying to understand it :-)
Found the file let me read it.
Best,
VMP
dieter
You're right! I think it was Einstein who said "50% is theory and 50% is experiment."
And Richard Feynman wrote a half a page of text to express: if the experiment doesn't validate the theory then the theory is wrong.
I find it extremly entertaining to see those highly educated, established people, having to discuss this question. Something that even a chimp understands immediately.
Well, nothing against Feynman, he just pointed out that some of his collegues would refuse to drop a theory only because they loved it so much, despite the fact that the theory was experimentally debunked already.
Like eg. Relativity Theory which could not integrate / was incompatible with the already known quantum theory.
Yep, build it. At least, it's easy to test for "Lenz-Freedom": with a certain RPM, you measure how long it takes the rotor to stop, first with an open, unconnected coil, and then with a shortened coil. If these times are the same (provided the coil is quite effective in current generation in this setup), then it's Lenz-free.
darediamond
Quote from: Madeo on December 24, 2014, 04:04:20 AM
Hi guys,
I'm glad to see something really productive being posted here.  I was thinking that rather building a completely different generator/motor that is lenz free,  it would be equally just as effective if we can attach a regular generator to a Bi-toroid transformer. The generator would not feel any more resistance under load than it would be without one. Of course, building a Bi-toroid transformer is difficult but easier than a completely new type of generator.
I do not think building a bitoroid track is hard if you are going to use powdered  carbonated iron, Resin and accelerator and catalyst.
Simply Get 5mm thick Veroo board or Plywood, Matt knife, Iron Ruler, Glue and with these items make a Splitted Mould which you would glue together and a Bobbing.
Most bitoroid Cores are Square in shape. So you just need to cut out the divide that Square into 2 when cutting making your mould. So this means you will have two separate c shapes cores which will be taped together after the whole assembling.
Madeo
dieter
That would require a functioning Thane Heins Bitorroid Transformer. Personally I haven't verified this principle, and what I've seen on tube etc. is contradicting.
Also, I am having problems with the principle because it expects the CEMF to take a path on which it will collide with an opposing flux (the other half of the CEMF). It may however be true that at a certain degree of saturation of the main core, the CEMF takes indeed the additional, outer path.
It's an interesting thought, but a lot of research work in the bitoroid business would have to be done beforehand.
Here2njoy
Speaking of Thane Heins he has resurfaced with another Youtube site  https://www.youtube.com/channel/UCBslCeRonaXNJ0x_g_ZTEew
He seems to be posting a lot lately.
Cheers,
