Lenz free generator
0 Members and 42 Guests are viewing this topic.
tinman
Quote from: i_ron on August 19, 2016, 11:05:52 AM
Brad,
I am not entirely in agreement with JB's statement in his videos that this, 'Zero Force' is a non-generator.
Naudin showed way back when that this configuration can induce a voltage.
Ron
That is correct Ron.
Any time there is an external magnetic field changing in time with regards to an inductor,will cause a voltage to be induced across that inductor--and so it becomes a generating coil.
If there was no induced BackEMF from the magnet in motion to that of the inductor,the current would go sky high.
Brad
i_ron
Hi erfinder, all,
with  erfinder's encouragement, he suggested I not give up on version 1,  I put the 6 pole rotor back in business.
Adding a generating coil shows the nice sine wave on that coil.
But this is where it gets interesting, lightly loading this coil does not upset the motor too much. Anything less that 300 ohms and the motor gradually slows right down.
But... with a speed of 2045 RPM and a no load output of 4,86 volts... putting a 300 ohm load on the coil will, over several minutes, drag the RPM down to 2000 and the voltage down to 4.09 volts DC ((FWB, 1000 uF)
It has just run like that for 30 minutes.
A clarification, the motor draw is very much RPM sensitive, 300 mA at 1200 RPM, 200 mA at 2000 RPM. So there is no discernible input meter movement when connecting the load or disconnecting the load.
Ron
Enjoykin2017
Hi Guys !!
Let's start from the very begining.
Prime question is: "Does the test electrostatic  charge/s (electron/s) and permanent magnet (both poles) interact among themselves or not interact and why is so ??".
There is our small experimental setup: Take a glass tube. Clean it from greased sweaty hands with alcohol. Now rub one end of a glass tube with synthetic fabric, and suspend it for the middle by means of a rubber flagella to a rack and bring at in vicinity permanent magnet near the polished end of glass tube.
1. Is there exist any kind of ineraction or force between test electrostatic charge/s (electron/s) in close proximity of southern or northern permanent magnet poles ??
Guys now do the same, but with non polished end.
2. Any interaction or not ??
To undesrtand any electro-magnetic paradox it was quite necessary to understand on prime experiment does the electrostatic test charge and a magnet interact among themselves ??
pps: "Physics stands on a stable foundation of the facts, but not on drift sand of imaginary hypotheses", E. Rutherford.
"semi-permanent" ,Dog-One ? I think someone call this "Hybrid magnet" !
The 45 Tesla Hybrid Magnet - Strongest Magnet Ever Built  It could pull your tooth filling out from half a mile away!
forest
Just take example from EmJunkie thread and use the rised current in one leg of mutual transformer to create field around the resonant tank circuit or a lots of coils in some special configuration or non inductive position, basically without loading the input.[size=78%] [/size]
[size=78%]Looks like the Kapanadze aquarium box[/size]
