Lenz free generator
tinman
Quote from: EMJunkie on September 04, 2016, 04:48:19 PM
Hi Ron - A very good friend of mine invested many thousands of dollars and a lot of time in the Squires Device.
The Murakami Army will have you believe that a Bar of Soap is OU, I say you really need to be wary of Aaron and Soap!!!
It does suffer from Lenz's the same as a normal motor. I really should not post any pictures as they are not mine to post, but:
   Chris Sykes
       hyiq.org
Chris
I dont know about how it would perform as a motor,but i think it would make a very powerful generator.
I believe we have a means of a simple version,using two of the same shaded pole motors,and replacing the rotor with a diametrically magnetized magnet.
Perhaps most of the CEMF would remain within the core loop,and each coil would buck the other?.
I think i may have two identical shaded pole motors to carry out the build.
Brad
tinman
   Chris Sykes
       hyiq.org
Well,turns out i did have two identical shaded pole motors for the experiment.
All i have to do now,is cut through each core,through the middle of the bearing carrier holes.and tig them together. We then have something similar to the one you pictured--but at a budget cost. ;)
Brad
EMJunkie
Quote from: tinman on September 05, 2016, 03:54:22 AM
Brad
Brad, the center of the device, the Ward Force Generator, is a Magnetic Base Dial Indicator.
The Magnetic Base Dial Indicator, has a Core, Magnet and also some extrusions that are important. Let me do some pics and post, give me a few hours.
   Chris Sykes
       hyiq.org
P.S: The Red is a non Magnetic, Alloy housing. The Magnetic Base Dial Indicator is made from two parts, it has the Magnet on the inside.
shylo
Hi Brad, when you cut through the laminates won't that ruin their function? Since they are insulated from each other.
Just asking. artv
tinman
Quote from: EMJunkie on September 05, 2016, 04:13:22 AM
   Chris Sykes
       hyiq.org
Yes,yes--i know exactly how they work.
I was thinking more along the lines of a generator.
In this case,we basically have a bucking field toroid generator.
Now,suppose when we draw a load from each coil,we use a switched connection from the coil to the load--like a mosfet switch on each. We then have a circuit that enables us to close each mosfet independent from each other,and at what ever frequency we decide on.
What would we produce if say the switching frequency of one coil was 100Hz,and the other was say 130Hz. What happens when we have two magnetic circuits,in the same toroid core,being loaded at different frequencies,when the inducing field has a fixed frequency ?.
So,we will chop one AC wave produced by one coil at 100Hz,and we will chop the other AC wave produced by the other coil at 130Hz-and we get what?.
Core done.
Brad
