ZERO INPUT, 10 degrees thermal output...Yes,...genuine free energy
Started by TheoriaApophasis, December 22, 2014, 05:54:57 PM
profitis
Infact, with bismuth,you can simply spray-pyrolysis sulfur vapour on one side of the block and convert to thinfilm bismuth sulfide(Bi2S3) for extreme intimate semiconductor/bismuth contact point for thermoelectric extraction at great efficiency
MarkE
profitis
mscoffman
I'm seeing what I consider errors in this thread.
1) I don't think that a constant magnetic field can rotate - there is no such operator. lines are fungible + there is no index.
2) I think a magnetic field with differences the differences can rotate but the magnetic field itself doesn't
It's probably one of those things that only certain theoretical situations cause you to need to use valid
theoretical views.
3) In a homopolar generator the magnetic face must be constant and must include the edges of the conductive disk(s)
4) In a homopolar motor the magnet must only partially cover the conductive disk face.
5) The homopolar motor reversed is a standard generator with a small part of the disk generating flux but is not a homopolar generator
Metals are Fermi Seas - unbound shared electrons galore.
I also have found a reference that says it is theoretically predicted that bismuth209 will be an excellent LENR catalyst
but that the 100% pure bismuth metal matrix won't support D deuterium flux in this case. An bismuth iron alloy has 2% the matrix
spacing of Pd. This is saying that the exact alloying configuration of this sphere is probably critical. It would pay to have heavy water
or D^2 gas in the atmosphere around it to boost heating. Large B flux is desirable.
:S:MarkSCoffman
profitis
Well I did an experiment now and I can definitely say that there is a tiny current when a strong magnet is contacted direct onto bismuth with the bismuth contacted onto amorphous bismuth sulfide.the current was about one fifth a micro-amp continuous in this case.weaker magnets gave less current.I feel there is something going on here
