FREE ENERGY has been discovered =Electricity Multiplier
Started by that_prophet, January 06, 2015, 10:18:08 AM
isawit
Quote from: Paul-R on October 07, 2017, 11:03:17 AM
One day, isawit, you will understand how much you know.
what do you mean? can you debunk anything i said?
Temporal Visitor
Quote from: isawit on October 06, 2017, 09:21:23 PM
none scientist, or any science paper, has a clear, rational, precise definition of energy.
what is energy?
energy is moving electrostatic force carried by moving matter.
nowadays everything energy, everything quantum.
do you really know what is energy? not even einstein.
what is ENERGY?
coal? fuel? oxygen? wind? sunlight? any matters?
NO. matter is not energy. matter is the carrier/source/container of energy.
a rock at rest only has its thermal energy.
if you threw it away, your hand put a force on the rock pushing it moving at a speed v, the moving rock will have 1/2mvv energy added on it. we call it kinetic energy.
if the flying rock hits a wall, that energy becomes the impact force that hits the wall, makes atoms on the wall vibrate faster/hotter, atoms thermal energy.
so, energy is nothing but vibrating force/moving force.
energy is always vibrating/moving, within and between matters. the matter is always moving/vibrating due to the existence of energy.
nothing is ever at rest, keep moving, changing, involving, reforming, transforming.
somehow, LIFE woke up?
OK; fine and so what? Having a precise "definition" of a WORD is not going to provide usable POWER for people any more than the word "ENERGY" itself ever will be capable of.
People are free to believe whatever they choose but the fact of them having any particular belief does not in itself make that belief true.
To believe that energy is even real, meaning a thing with physical existence is to deny the reality that energy is merely a WORD naming a conceptually based system of measurement and accounting for real WORK done on and or by any and all physical objects made of matter having mass.
ENERGY is word that has been loosely defined by the physics community to mean; "In physics, energy is a system's capacity to perform work, which is force acting on an object that effects displacement of that object. Energy has many forms, including kinetic or mechanical energy, potential energy, light energy and heat energy. The basic rules for understanding energy are the laws of thermodynamics." https://www.reference.com/science/energy-d5cd8747b45f071f?qo=contentSimilarQuestions#
WORK is another word that has been defined by the physics community to mean; "In physics, "work" is when a force applied to an object moves the object in the same direction as the force."
More fully explained: "In physics, the equation for work is W = f x d. This means work equals force times distance. Distance is typically measured in meters. The force is a measure of the mass of an object times its change in motion, or acceleration. This is measured in newtons. The amount of work done is measured in joules."
Again I write: SO WHAT. All of the above are just words, they do no work. Yes they have great importance and are part of required learning but they are only a small part of learning how little any of us truly KNOW: IN REALITY.
Personally at this point in my life I am not too terribly concerned with definitions of the word "ENERGY" that in reality can only be thoughts from the imaginations of others before me. However their thoughts are useful, and notice is taken of them so to be able to articulate my own thoughts to others who might think and do further for themselves.
True learning about "energy", force, and power comes from DOING WORK WITH MATTER DOING WORK and observing what does what and searching for Truth as to how and why ALL THAT IS - IS WHAT IT IS. If you haven't yet done so - give it a try - its not cheap or easy but that is why it is called WORK.
When you get there, and you may - you WILL KNOW the answer to your last "somehow, LIFE woke up?"comment/question, and a whole lot more about yourself as well as the FORCE/POWER individually keeping you in the BIG PICTURE we call life.
isawit
what's the point? what else do you know? can you share?
forest
I don't like to talk much cause English is not my native language. There is no law of physics to limit work done using energy - and magnetic field is energy and it's free - if you push many electrons using low energy you get more energy....
isawit
The greatest, most approved law says f=Ke x q1q2/rr.
That force is a real thing, connected all free electrons in all matters at all the times.
Magnets have magnetic force, but magnets have no energy. Only a moving magnet has energy, it has moving magnetic force.
A charged particle has electric force, but it has no energy. Only a moving charge has energy, it has moving electric force.
Planets move in orbits have kinetic energy, electrons vibrate on the surface of atoms have vibrating electric force/ac current.
Electrons can only vibrate on the plane perpendicular to atom radius, the energy propagates at 90 degrees/radius direction.
Electrons on the surface atoms of matters are directly connected with electrons on the surface atoms of the line of sight matters. The connecting force f=Ke x q1q2/rr transfer energy/moving force at infinite speed.
All star lights we can see at night is instantly ongoing energy carried by vibrating electrons on those stars.
There is no past or future in reality, the reality is ongoing now.
